picked up my Exclusive Estate 2 liter hdi
jacksun1987
Unread post by jacksun1987 »
Picks up Bryan s hdi Exclusive Estate.
Very nice just need to get my seat sorted get in the comfort zone.
Theres 1 or 2 things what need sorting on it.
When the fans on full blast the warning lights come on. Is this a dogy electrical problerm. What not worth worrying about. Or does the coolant need changing ?
Is it easy to get a new rear arms bearings bryan said it might be. Or they might just need greeceing
has anyone got rear door trim (external) on the drivers side in green Or maybe get spray paint on a black one
would this fit my boot ?
http://www.ebay.co.uk/itm/xantia-1994-1 ... 4d151cbbef" onclick="window.open(this.href);return false;
Ohh ya where the suspion sport button is theres another one next to it. Whats that botton ?
thats bout it really till i think f some more questions lol
Cant wait to have a full day to have a play in it get to know the car better.
thanks
BA-CAM
Re: picked up my Exclusive Estate 2 liter hdi
Unread post by BA-CAM »
Hi Paul,
I will send you a pm with more details.
Bryan.
'99 xantia Exclusive 110HDi Estate
Previous;
'99 xantia SX 110HDi Estate
'00 xantia Sx 90HDi Estate
'96 xantia estate 1.9td
BX Estate 1.9 non Turbo
red_dwarfers
x 58
Unread post by red_dwarfers »
You've upgraded a bit haven't you Paul, all those buttons to press! Hope it proves to be a reliable steed.
Kev
'19 C4 Cactus 130 Flair
jacksun1987
yep too many buttons lol. I really hope so sure it will be
bigal
Unread post by bigal »
Hi Bud, if its like mine there should be two buttons, one each side of the sports one, they are for your suspension settings, up and down
Northern_Mike
It switches off the internal movement sensors for the alarm. You'd use it, for example, if you wanted to lock the doors with a dog in the car so it didn't set the alarm off when it moved around. It resets every time you switch the car on.
Citroenmad
x 110
Unread post by Citroenmad »
Do you mean when the interior heating fan is on full or the engine coolant fan is on full?
jacksun1987 wrote: Is it easy to get a new rear arms bearings bryan said it might be. Or they might just need greeceing
That is a hatchback parcel tray. You need the one which looks a bit like a roller blind.
jacksun1987 wrote: Ohh ya where the suspion sport button is theres another one next to it. Whats that botton ?
As Mike says or perhaps it disables the rear windows from use by the rear passengers.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
jacksun1987
nope its when the heating on full the stop light comes on. Found out when i put the face air vents on. Doesnt seem to do anything. But when i put the dimisters on. The stop light comes on lol
french electrics i think. Think the button for the lumber support as stopped working. Ohhh no no lumber support what shall i :( do lolollol
Changed the oil in it yeasturday. And bled the fuel pump. The turbo kicks in so much sooner. Well it seems i can hear it better the before.
It goes like a rocket. I like it on the sports mode its superb. :)
Theres one thing we found out. The reason why the hand break lever. Is high. Is because the break cable has snapped. On the passengers side. And there is a quite a lot of play in the ball joint .
Still cant hear this arm bearing thing creaking though. I think the only time i thought i noticed it. Is when im reversing and turning slow.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I shall tell you EXACTLEY what the warning light is Paul.....
When you are on demist the Air Con is automatically activated weither the main dash switch is on or not!! Its a feature to assit windscreen demist as air con is also a de Humidifier..
Anyway, the warning light is telling you the COOLING FANS are not working!! Honest! I bet you they aint working.
That will be cooling fan plastic cover off and between the fans theres a small triangular box, in there is three relays, Id be betting one of the pins on one of the three relays is corroded...
Buttons on the right, Hydractive suspension, Alarm Ultra sensors cancel (Loud speaker diagram with a cross on it), Rear window switch's for electric windows Disable (thats the one with two arrows pointing up and down with a cross on it)
A very sad...
1994 XM 2.1 d auto
boristhespie
x 4
Unread post by boristhespie »
What year is your exclusive. I have an 06 and there seems to be no buutton for sports suspension just the same two button jobbo as my 02 lx. Did this come in later or was it an optional extra?
C'est pas possible!
citroenxm
Fallen Hero
x 70
This is a xantia that the topic is about ... boris not a c5 ..
A very sad...
1994 XM 2.1 d auto
Citroenmad
x 110
boristhespie wrote:What year is your exclusive. I have an 06 and there seems to be no buutton for sports suspension just the same two button jobbo as my 02 lx. Did this come in later or was it an optional extra?
With the C5 the hydractive+ was a feature depending on engine and not spec, unlike the Xantia.
You need a 2.2HDi C5I or C5II or a 2.0 and over petrol. Unfortunately.
03 Seat Arosa 1.0S
jacksun1987
Just noticed somthing. When i was waiting for the car wash. I had the steering wheel slightly turned. The suspernison started making funny sounds. Is that normal?
Like if it was pumping more
Northern_Mike
Yes.
Don't use a car wash machine. The brushes do horrid things to the paint.
jacksun1987
Just so much faster.
The nearest hand presser whash near me is all right. But its very muddy. Make the car look nice but. Muddy mats
