Xantia P2 Seatbelts
xantiagreen
Re: Xantia P2 Seatbelts
Unread post by xantiagreen »
Hell Razor5543 wrote:Based on the fact your OP says Forte (which is Citroen for LX!), and from what I have read on the forum, you almost certainly won't have the wiring for any seat electrics other than for the side airbags. The SX and above had the loom and connectors in place, even if the seats were the basic variety (although you still needed to fit some fuses, including a maxi).
Looks like no leathers for me then, quite fancied resting my left arm on the arm rest. Has anyone tried the universal arm rests with storage compartment that can be fitted over the centre console and screw into the side?
http://www.ebay.co.uk/itm/Armrest-Centr ... 232fbeebc5" onclick="window.open(this.href);return false;
http://www.ebay.co.uk/itm/Leather-Car-A ... 232eed71cb" onclick="window.open(this.href);return false;
http://www.ebay.co.uk/itm/Arm-rest-Armr ... 3cd8c2a006" onclick="window.open(this.href);return false;
Cheers
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Good Try James BUT!
I have fitted S2 Leather into an LX.. The amazing thing is the Plug for the Sunroof Switch is STILL under the centre console..
So when I fitted the seats I picked up a + and - Feed from the sunroof switch and took it to the seats... It was rather easy to do really, BUT I did have to upgrade the Fuse box fuse slightly..
The seats will fit in perfectly fine otherwise. Just a bit of wireing to do if you understand electrics (Which in a car is not that hard really!)
A very sad...
1994 XM 2.1 d auto
xantiagreen
So she shall have leather seats (at some point) which are better Series 1 or series 2 leathers, even if I don't have a sunroof, will the switch still be under the console, also anyone fitted those centre armrests?
Cheers
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
citroenxm
Fallen Hero
x 70
You get some series 2 leather you will get an arm rest ALREADY fitted!!
S2 leather more common in electric, S1 is about but useually manual, unless its come out of a V6, but S1 V6's rare, they werent out till Late P reg, and the xantia changed on late R reg..
A very sad...
1994 XM 2.1 d auto
xantiagreen
Seen a full set series 2 leathers £150, look nice need to get all things sorted on car before getting a set. Most likely will be mechanic fitting them and his son doing the electrical work, don't want to have to get a new loom fitted coz I've bodged something up.
Cheers
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
Eddie Nuff
New User
x 38
Unread post by Eddie Nuff »
citroenxm wrote:Just a bit of wireing to do if you understand electrics (Which in a car is not that hard really!)
:rofl2: :rofl2: :rofl2: :rofl2:
Yeah right! [-X
citroenxm
Fallen Hero
x 70
Wooos.... you cant even use a Multi meter... :rofl2: :rofl2: :rofl2: :rofl2:
You'd run a mile then if you saw the mess my XM project is in, but im getting there... :? :shock:
A very sad...
1994 XM 2.1 d auto
Eddie Nuff
New User
x 38
Yeah! and who was it who told me to get one of them silly yellow boxes with the funny writing on it?
It doesn't even say which way up you hold it! :-D #-o
citroenxm
Fallen Hero
x 70
Re:
Eddie Nuff wrote:Yeah! and who was it who told me to get one of them silly yellow boxes with the funny writing on it?
:rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :-D :-D :-D :-D
A very sad...
1994 XM 2.1 d auto
x 5652
Re:
You get your assistant to hold it/read it and then yell at them when the magic smoke comes out.
xantiagreen
Hey, fixed the poor retracting seatbelts all round using Everb___d Dry Silicone spray, ordered 2 more cans. Followed Xantidote sprayed both sides of belts and openings gave all the belts a good 30 second work out and now they are like new, kids will have to get used to the belts pinging back now.
Cheers Xantidote
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
I had complaints from my oldest daughter about that! My seat belts Really tight!! :-D
'58 C2 Code
'58 partner teepee outdoor
xantiagreen
Hope they stay that way Timmo, hopefully wont need to use the 2 cans I've ordered.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
davek-uk
Unread post by davek-uk »
I solved my poor retracting rear belts by reshaping the plastic trim that they pass through. I had taken the lot off and sprayed the belt drum without success - even removed one to try and retention it (never again). In the end I reshaped the covering plastic and slightly widened the "ring" they run in (but this was difficult). I've been quite amazed that after two bouts of 2-3 year rest periods, they still work and she passed her MOT again yesterday!!!
I can get some photos but I have no on-line photo hosting account...
Pug Rifter long (20) - 41mpg - Gutsy for a 1.5!
Xantia 1.9 TD Temp.2 Break (97) - 208K@42mpg - Resting again.
Berlingo Multispace 1.6 16v (51) - 184K@36mpg - My shed! Still runs 15° retarded...
xantiagreen
davek-uk wrote:I solved my poor retracting rear belts by reshaping the plastic trim that they pass through. I had taken the lot off and sprayed the belt drum without success - even removed one to try and retention it (never again). In the end I reshaped the covering plastic and slightly widened the "ring" they run in (but this was difficult). I've been quite amazed that after two bouts of 2-3 year rest periods, they still work and she passed her MOT again yesterday!!!
I agree the rear belts don't seem to be flush and straight they always look slightly crumpled in, poor design I think. Do your belts sit straight when retracted, over time I suppose that can cause a problem when retracting.
Use photobucket, sign in easy and you can copy and paste the links into your post (That's the way I've done it in past, I think) would be good to see your method.
Cheers dave.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
