hi everyone.i have an 02 c5 hdi.the last time it was serviceg the sump stud
seemed to pull the threads on the sump,so just had to chemical metal it
back on solid.took the car to get service yesterday and he sucked it out
with an oil extractor.is this a good method?the reason i ask this is because
it didnt seem to suck out the amount of oil i thought would b in the sump.
he also over filled with new oil,is this ok?
c5 service
Stempy
Re: c5 service
Overfilling with oil is never a good idea, best get some sucked back out before something blows.
You can get the thread reapired with a helicoil or similar but probably best done with sump pan removed.
Lexia ponce
Lexia ponce
Jeff
Re: c5 service
Take it back and get a drop of oil sucked out but as long as during the service the majority of the oil was removed and a new filter fitted leave it alone. If your still concerned bring forward a couple of months the next oil change.
BTW up until last month (and for the previous 12 months) I had the max oil warning when starting my car. I'd only marginally overfilled it and have a dodgy sump thread like you so was not going to drop the small overfilled amount out.
If you start your car for a minute and turn it off and then restart you'll probably find the oil level in the sump is almost nothing, so I took the view it was good to have the over filled warning but in practice it would do no harm being slightly overfilled.....but as you have paid a garage take it back, its a quick fix for them.
Currently driving Citroen c5 2.0 HDI 51 Plate
qprdude
- x 14
Re: c5 service
Depends how much is overfilled. A minimal amount won't do any damage but it's not best practice. If it's more than 5mm above the high mark get it removed.
As regards sucking the oil out with a Pella pump, a lot of garages do this now, especially those advertising cheapo services, but even some BMW garages do it now. The suction pipe goes down the dipstick tube and often drops very close to the drain hole so it's not a disastrous way to do an oil change.
Rick.
2013 Citroen DS 5 D/Sport
- x 3277
Re: c5 service
When my mother has her boat serviced, they have to use this way of getting the oil out, as the sump plug is nigh on impossible to see, let alone get a spanner on.
Northern_Mike
Re: c5 service
I use one on everything now. Didn't use it last time on the Berlingo because I'd filled it with old oil by accident and wanted to make sure it was completely dry of it. Used it twice recently on the Renault 4 engine in the DRK and got all the oil out both times.
mm1
Re: c5 service
thanks for all the replies guys.he overfilled nearly an inch,up to where the twist is on the dipstick.
the reason i asked was it a good way of taking out the oil was just because the sump looks slanted
back at an angle and it hard to imagine the small little pipe getting back there.
qprdude
- x 14
Re: c5 service
I'm wondering if the mechanic didn't try too hard to remove the old stuff. In theory the suction pipe should go to the lowest part of the sump or very close. If the pipe was pushed too far, it would coil upwards again and leave old oil in the sump. Assuming he made an effort to find the oil capacity of the engine , he would have put that amount in. If he hadn't sucked out all the old oil, then the level would certainly be too high. It would be poor practice for a mechanic to make a guess at how much oil was required, so you could have some old crap amongst your new oil.
Rick.
