Hi Guys,
I have a Citroen C5 2.0 HDI Exclusive with NaviDrive (not the 3D). The audio systems does something weird I couldn't find out why.
The audio on the left side sound good. On the right side the volume is slightly lower than on the left side. After a while the volume
on the right side goes equal to the left. After a while again, the volume goes down again. I might think about a connection failure
but not sure. My other guess is the Parrot CK 3000 BT device. I don't use it, my phone is not paired with it.
What do you think? Did any of you recognised something similar to my problem?
Regards,
Balázs
Citroen C5 Audio problems
vborovic
- Locked user account
- x 40
Re: Citroen C5 Audio problems
I'm guessing you have the latest C5 (2008 - ), can you identify your navigation unit (there are 4 different ones that can be in the car) on the following link: http://gpsunderground.com/forum/peugeot ... s-psa.html" onclick="window.open(this.href);return false; ... then we can start from there ...
Aryo
Hi,
I got this kind of nav unit ...
http://gpsunderground.com/forum/attachm ... 670194.jpg" onclick="window.open(this.href);return false;
vborovic
- x 40
That should be the RT4/RT5, don't know which one exactly ... I'd start by checking the cables in the rear (connect & reconnect), you need to pull the nav unit out (there are some specific keys/handles that exist to unlock and pull out the unit) ... I'll try to find the user manual for it, maybe a soft reset would help (if it is not a hardware related problem).
