Rear LHM leak
- x 1485
Re: Rear LHM leak
Ah, OK... On the C5 the ram is bolted into the subframe. Not sure you can remove it with the sphere attached - not enough room to get the bolts out maybe. It may well be possible to replace the gaiter with the ram in situ if you have manged to free the ram from the arm (lucky bugger!) - and since you have the pin out, there is no need to remove the arm. I would go along with repairing the pipe, and then trying to get the sphere off - you just need a bigger lever and / or a bigger hammer
philthyD
Re: Rear LHM leak
So the only thing left that I'm not clear on is the seals themselves I used to have a diagram which showed me where they went but I seem to have misplaced it while waiting for the gaitor to fail completely.
This is all very useful information I am very grateful to all who have contributed.
'01 Cit C5 2.2HDI SX +toys *rescued and undergoing dpf removal*'95
Nissan micra*crashed*
'96 Nissan micra*crashed*
1979 Datsun Cherry*sold*
'95 306 Dt *written off*
'97 306 Dt *aux belt destroyed timing belt, dead*
'98 306 Dt *part ex'd*
'99 406 2.0HDI exec est *dead*
philthyD
Re: Rear LHM leak
Oh and to add, I have just managed to replace gaitor while ram is in situ, it was difficult but all I had to do was unbolt the antiroll bar to allow the arm to move freely which allowed enough room to maneuver the gaitor around the end of the ram.
c.morewood
- x 55
Re: Rear LHM leak
Just to finish off this thread...
I thought some of you might be interested in this
Late Xantia 2 /C5 conversion to Xantia fittings for both front and rear cylinders.
Made up by Big Mick at http://www.Eurocarcare.net" onclick="window.open(this.href);return false;.
Notice how their Xantia fittings are larger and less prone to rounding that the standard citroen fittings.
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
c.morewood
- x 55
Re: Rear LHM leak
As a hopefully last post on this thread. I've just changed a leaking cylinder seal/edge for a dowty one, in situ, in about 2 hours, rather than the 2 weeks it took me in this thread.. instructions on the "Dowty seals work" thread viewtopic.php?f=3&t=46231&start=15#p570522
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
