Rear LHM leak
c.morewood
x 55
Rear LHM leak
Unread post by c.morewood »
Doesn't it always happen at the most inopportune moment?
I was just putting on my newest winter tyres due to the amount of drifting snow today. (My wife's working a night shift 20 miles away across country)
And had the suspension on high, when I spied this LHM leak dripping from the rear n/s suspension sphere.
This is my first experience of an LHM leak. Could the more experienced of you give me an idea where to start?
As you can see it's dripping off the bottom of the sphere and the R clip about 1 drop each per second if that helps.
I've checked in the archives and I think I can rule out a sphere seal as the seals haven't been disturbed for the past couple of years.
Or do the seals tend to rot. I hope it could be as simple as a seal.... fingers crossed.
Could you give me an idea of where to start and what might be involved? Is it a simple job or is it one for the garage?
Pictures on page 3
Thanks,
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
x 1489
Re: Rear LHM leak
It can only be the sphere seal, or the end of the cylinder rotted away - first thing is to get the sphere off, clean it up and have a look.
Lighty
x 34
Re: Rear LHM leak
Unread post by Lighty »
Almost certainly the cylinder rotted away, never known a seal just fail, I would source a new cylinder before starting.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Old-Guy
x 25
Re: Rear LHM leak
Unread post by Old-Guy »
And everything else looks horribly rusty under there.
c.morewood
x 55
Re: Rear LHM leak
Yes lots of the brown stuff.. I guess its due to the salt and grit they use on the roads for 5 months of the year up here.
Well I tried the seal and you guessed it.. it wasn't that.. I just made the leak worse....so I guess its the cylinder then... whats the chance of breaking a pipe whilst renewing the cylinder.. the way my luck is going at the moment.......
Do the pipes have seals or are they just pressure sealed like the injectors?
Thanks for the advice guys as always its welcomed.
'94 Fiat TipoTd 40K
x 1489
Re: Rear LHM leak
Odds on you will break the pipe getting it out - one of the pipes to the rear unit went on mine went recently (rusted through where it's clipped on the subframe), and the pipe was rusted into the nipple, so just twisted itself off when I tried to unscrew it. The other end is fitted into the anti sink valve - mine came out OK (but you might need a decent 8mm brake pipe spanner to get it out. Mind you if the pipe is scrap at the cylinder anyway, then just cut off. You will also probably need to cut off the R clip as well. There is a seal on the pipe, but chances are it will stay in the housing - I just fit the new pipe and it seems to seal it OK. Plaeides near Cambridge can make up and supply a new pipe by post - it's a special end fitting for Citroen, so people that can make it up are limited these days. Which side is it? OS pipe is 1100mm, NS is 950mm.
c.morewood
x 55
Re: Rear LHM leak
Its the N/S Richard.
I've been looking at the Citroen website trying to make sense of the Diagram. (Sorry Given up trying to get it to display)
'94 Fiat TipoTd 40K
electronmirror
x 30
Re: Rear LHM leak
Unread post by electronmirror »
Surely that picture relates to the hydraulics at the FRONT of the car, so item 9 is the feed to the top of the near side strut ?
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
c.morewood
x 55
Re: Rear LHM leak
Hi Ted,
Sorry I was so busy trying to get the page to display properly I completely missed that I'd selected the wrong one.. fixed now!
'94 Fiat TipoTd 40K
x 1459
Re: Rear LHM leak
Unread post by xantia_v6 »
I think that you are looking at the wrong page. You want feed pipes, not return pipes.
Xantidote
x 4
Re: Rear LHM leak
Unread post by Xantidote »
xantia_v6 wrote:I think that you are looking at the wrong page. You want feed pipes, not return pipes.
Yes, that's my thoughts as well. The rubber boot, which covers the suspension cylinder's operating rod, as well as keeping dirt out of the cylinder/piston, has 2 flexible tubes connected to it, and these are what I see in the diagram you've posted.
Might be worth trying a few doses of Plus Gas on the feed pipe banjo connector at the cylinder. Worth a little perseverence on this to avoid having to renew the pipe, although easier said than done in this weather (unless you are lucky enough to have a nice warm garage). If the nut rounds off because it's rusted so much, then careful use of molegrips may help, though over-zealous force on very corroded nut can lead to the fitting becoming crushed
Good Luck - always seems to happen at most inconvenient time
Martin
1995 Xantia TDLX (deceased :( )
c.morewood
x 55
Re: Rear LHM leak
Thanks Martin.... Feeder pipes... ok... I'll have to have another look and try to find the correct page.. As I said, I'm new to anything suspension related with the Xantia as up until now she's been ultra reliable. I'm just glad the leak sprung when I was changing wheels and not on the road!! I think I might as well do a Hydraflush cycle at the same time.
Thanks again for all the advice,
'94 Fiat TipoTd 40K
x 7163
Re: Rear LHM leak
You may be able to pick out some useful information from my tussles with replacing a rear strut on my Xantia
Xantia Rear Strut
The "R" clip which retains the cup in the radius arm which accepts the push rod from the rear strut cylinder was completely rusted in and took some getting out.
Kind regards
PS there is also this follow on thread re the rubber boots and clips
boots clips etc
x 94
Re: Rear LHM leak
Unread post by citronut »
here are N/S/R feed pipe part No.'s for ative WO anti roll
and they are both NFP
9
5270 C7
NFP
HYDRAULIC TUBE
- UNTIL RPO 08056
5270 LJ
NFP
- SINCE RPO 08057
and with anti roll
and non hypa active
06
5270 A2
HYDRAULIC TUBE
LEFT
DIAM 3,5 L=951
- UNTIL RPO 08208
5270 PL
NFP
LEFT
DIAM 3,5
- SINCE RPO 08209 UNTIL RPO 08518
5270 A2
LEFT
DIAM 3,5 L=951
- - SINCE RPO 08519
Regards, malcolm.
x 94
Re: Rear LHM leak
c.morewood wrote:Hi Ted,
its still showing return circuit
Regards, malcolm.
