Lexia or KWP2000? Retro fitting Cruise Control on a Xantia?
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 70
Re: Lexia or KWP2000? Retro fitting Cruise Control on a Xant
I was lucky enough to of removed a couple of Full Engine Looms so had spare plugs and pins and wires and did this above exactley..
I tried the wire fold over but wasn't clever enough and it kept shorting out on the next. But perfectly fine after useing the proper pins.
I worked in Cable harness manufacturing for 16 years, so it was quite easy to remove from the donar and fit to mine..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Excellent explanation! Thank you very much!
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
C5 2005 2.0 HDI 138
- My Cars: Citroen C5 Tourer 3.0 V6 HDI 240 2009
After reading this thread I have installed the wires, the switch and the stalk and enabled cruise control in the ecu PR. No.8550. instead using a relay for the NC break switch i have modificated the brake switch like this
The Problem is i keep getting a fault: brake switch coherence P0571. When I press the brake very slowly i can with my Lexia see that the first swicth to be activated is cc NC swicth and shortly after the brake light switch.
How closely should these switches operate after each other ? should it be simultaneously or should there be larger gab ?
I have now installed a relay and using that as NC brake switch, instead of the modified brake switch. And now it WORKS
- My Cars: C6 2.7 HDI '06
C5 2.0 HDI Auto '06
Xantia ACTIVA 2.0 HDI '98
Xantia 1.9TD '94 - dead
In the Spanish forum that I took this "how to", the guy made the same (or similar) to your brake pedal modification. And it worked. But the solution with a relay is just fine and quite easier
Was it possible ?PIT wrote:Later I will try to copy only the software to an older ECU, to see if it can run this way.
C5 2.0 HDI Auto '06
No The car didn't start.
We opened both ECUs to see if there are any differences. The PCBs looks to be the same, but on the newer ECU some chips are missing and some are different.
The ECU programming was successful, but the car didn't start. There were errors logged about injectors voltage... if I remember correctly.
The good thing was that the ECU was restored to its original software without any problems.
- My Cars: citroen xantia ACTIVA HDI
citroen xantia EXCLUSIVE HDI
citroen xantia ACTIVA TCT S2
citroen xantia ACTIVA V6 S1
Re: Lexia or KWP2000? Retro fitting Cruise Control on a Xantia?
Hello everyone!
I've read this topic a long time ago, and it was very useful, as I managed to install the Cruise Control on my xantia HDI. So, thanks!
Now, I want to fit in a trip computer, but the only one I could find turned to be from an english car (The seller sold it as a normal european one, and... big surprize), so it is in miles. Is there a chance to switch it in km? I have all the wiring installed in my car, but i cannot install this one I have in miles...
C5 2.0 HDI Auto '06
No, you can't. It is hard-coded in the display to show only MPGs and in software to calculate in miles and MPGs.
Only temperature can be set in C or F.
Then this is it. I'll try to find another one in km.
The cruise control works only in 4th and 5th gear. is this normal? in some cases it could be better for me to use it in 3rd gear too.
Also, I have a small problem, if I accelerate continous and for a long time in 5th gear from the CC stalk, I get the engine error; I have the engine software modified pretty much, but in normal mode, from the pedal I can do anything and it's working perfect with no errors. Any ideeas?
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 2993
The Cruise Control is only meant to work in 4th and 5th gears, and this is normal. This is how it is on my C5. I cannot help re EML; sorry about that.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- raynoon
- My Cars: 1982 Peugeot 104 GL, 1986 Citroen 2CV6, 1990 Citroen XM 2.1SED, 1991 Citroen XM turbo D 1992 Citroen XM 2.1 SED 1992 Citroen XM 2.1 SED auto 1992 Citroen XM 2.1 SD 1995 Citroen XM 2.1 EXCLUSIVE auto 2000 Citroen Xantia HDi 110 LX
Hello, we've tried to install cruise on my cruise activated Xantia, but we can't get it working. I've read and re-read this topic but I can't find any specific posts relating the the ECU pins and more importantly what wires go to which pins?
Can anybody enlighten me please?
1990 G Peugeot 205 CJ
1992 K Citroen ZX 1.9d auto avantage
1992 K Citroen XM 2.1 SD
1993 L Citroen XM 2.1 SD auto
1995 M Citroen XM 2.1td Exclusive auto
1999 Citroen Xantia Break HDi 110 Exclusive
2000 W Citroen Xantia HDi 110 Exclusive
1998 Citroen Saxo 1.0 Open Scandal
C5 2.0 HDI Auto '06
See the schematic diagram from 406.
viewtopic.php?f=3&t=39257&start=15#p326384
- raynoon
I'm not clever enough to read a wiring diagram. I'd just like someone to tell me which pins on the ECU correspond to which wire. I should have it sorted then.
C5 2.0 HDI Auto '06
What kind of stalk do you use? Genuine from Xantia or from other car?
