Removing 2.0 TCT engine and other Activa thingies
xantos
x 10
Unread post by xantos »
Well decided to remove the whole engine as the head is a PITA to remove. I managed to split the head from the engine block and I saw that the cooling channels are completely blocked. Have to clean them thoroughly and in the process I will also change the piston rings and check the turbo.
Anyone has some tricks that could help me removing the engine? And any other things I should do when the engine is out?
Here is how it looks now. Million things need to be disconnected... :roll:
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet :-D )
C4 Exclusive 2.0 HDi (gear shifting b****!)
Chris570
x 36
Re: Removing 2.0 TCT engine
Unread post by Chris570 »
I don't know where you are but if you want a replacement TCT engine I've got one for free as i need the space. It's located near bedford.
As for taking the engine out it's not that hard really, just keep on taking bits off that go from car to engine :)
The worst bits are the exhaust spring bolts and the o/s shaft can get stuck.
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'
xantos
x 10
That would be great but unfortunately I live in Slovenia, where we by the way drive on the right side of the road :twisted:
addo
Sara Watson's Stalker
x 95
Unread post by addo »
You mean the wrong side of the road! :P
I hope you have an engine crane and load leveller. It will be very useful.
xantos
x 10
And I made it! I managed to remove the famous 2.0TCT engine. And now the party starts! Getting all back together will be a piece of cake... :rofl2:
Pictures tell more than words so here they are...
x 1996
Unread post by Stickyfinger »
xantos wrote:And I made it! I managed to remove the famous 2.0TCT engine. And now the party starts! Getting all back together will be a piece of cake... :rofl2:
No they don't....Links broken :)
xantos
x 10
Sorry. Repaired. Better?
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
They are quite blocked hey!
Any idea what caused them to clog up so much??
I seem to remember from some of the 205 drivers that with minor mods the tct can make good power gains, porting & polishing etc. Cam, With forged pistons you can clear 200brake with not too much bother!
'58 C2 Code
'58 partner teepee outdoor
xantos
x 10
I don't know why are they so blocked, but I have cleaned them so now they are free.
I am very much interested in power gain if you have some more information...
Timmo
(Donor 2022)
x 168
I'm sorry, I don't have it personally as it didn't interest me, Mi16 owner! ;-) but will try and remember to ha e a look around the net tomorrow for you,
'58 C2 Code
x 1489
I think all you need for more smiles is a manual boost controller. It only runs 7 psi or something stock, but you can go up to 12 or 13 withouth putting the overboost light on, then it goes like a scalded cat!!
steelcityuk
Unread post by steelcityuk »
On mine I stripped the head then ground and polished the ports. The turbo manifold on mine had a rather rough finish internally and a large lump that must have been part of the casting process so I ground the lump out and smoothed the surfaces. Dropping in a quality clutch is usually worth while.
Steve.
not applicable
xantos
x 10
A bit of update.
Head grinded, valve seals changed, valve seats grinded.
Since I have the engine out decided to change the steering rack valves. As far as I know they tend to leak when you put hydrorincage into the system.
I ordered them at Citroen main dealer, price about 40eur, part.nr.: 4048.Q8. Hopefully I will never have a LHM leak again.
steelcityuk
Looking good.
Steve.
not applicable
xantos
x 10
Today's work...
