INDICATOR LIGHTS CONTROL STALK
pikecrazy
Unread post by pikecrazy »
Ok the right indicator wont stay on anymore just seems loose something has failed inside
Is it an easy fix to replace the stalk ?
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim :-)
VertVega
x 13
Re: INDICATOR LIGHTS CONTROL STALK
Unread post by VertVega »
_______________________________________________
Edit: I read your signature but I was not careful enough
and the stalk removal came for a Xantia
Stalk removal is easy. You need torx T20 and T10.
- Steering wheel cover is in two pieces and fixed with 3 screws (T20) from below.
- After removing screws, take off the upper half away.
- Steering wheel position so that the 2 stalks screws (T10) can be accessed easily (see pic).
- Disconnect the connector (pushing "nails" in and pulling off the connector) of the stalk.
- Connect the new stalk and test before putting all together again.
pikecrazy
Thanks for your help :-D
qprdude
x 14
Unread post by qprdude »
How did you know that without knowing what the car was? :?
Rick.
2013 Citroen DS 5 D/Sport
vborovic
Locked user account
x 40
Unread post by vborovic »
Maybe from pikecrazy's signature?
qprdude
x 14
You mean the one with TWO cars in it?
Rick.
vborovic
Locked user account
x 40
Yep, that''s the one ... :D
x 3298
Just a comment, I thought that the right stalk (on a Xantia) was for the wiper systems, while the left stalk was for the lights and indicators (and horn, on the S1). The OP was for the right indicators.
qprdude
x 14
Hell Razor5543 wrote:Just a comment, I thought that the right stalk (on a Xantia) was for the wiper systems, while the left stalk was for the lights and indicators (and horn, on the S1). The OP was for the right indicators.
Think the OP said the right indicator rather than the right stalk. Still didn't say what car though.(unless the 2000 Xantia and the 2003 Dispatch van have the same system of course
Rick.
x 3298
True, but if you read to the end od the first line in the signature it could imply he no longer has the Xantia.
x 1496
Sig implies it's for a Dispatch, which is much more likely as this is a std COMS2000 fault.... replacement is a bit more involved (and expensive!) than on a Xantia....
pikecrazy
Should of pointed out it's for the indicator stalk on the Dispatch :shock:
VertVega
x 13
I read your signature but I was not careful enough and the stalk removal came for a Xantia :roll: I have to edit my first message. Usually the current car is given in the first line and the sold/scrapped/gone car(s) added after that :wink:
It seems that (checking from ebay) Dispatch has either the conventional type of stalk or the new version COM2000 unit. If it is the newer version then it costs more and it needs more work to remove the unit.
qprdude
x 14
Yes, confusing. Current cars only in my Sig, otherwise I would need a couple of pages! :? :wink:
Rick.
