C5 Stereo replacement
cpikey316_
Ok, now I *think* i've got the engine problem sorted, its time to start making the C5 a bit more fun to be in!
Starting with a new head unit! Now, my dad (who has a MUCH newer C3) has been looking into it, and apparently the car will throw a wobbly if I plug a HU into it as it is. I don't want to do this however, as I do like the stalk controls, so i've been looking into things, and found this....
http://www.halfords.com/webapp/wcs/stor ... yId_165655
Now this appeals to me, and i think I need these as well
http://www.caraudiodirect.co.uk/ctsct00 ... o-c2-c3-c5
http://www.caraudiodirect.co.uk/ct24ct0 ... citroen-c5
Now, the question is, is that everything I need, or will there be additional parts/wiring harnesses I need?
Light bluey 2002 C5 LX
Fake Concern
- x 65
Re: C5 Stereo replacement
You may need another cable as well if you have parking sensors.
- x 1056
What C5 do you have ? Mk 1, 2 or 3 ?
If its a mk1 then that should be all you need, the connects 2 adaptor even creates a 'fake' ignition live for you.
cpikey316_
waynedance
- x 8
That should be all you need, changed mine for a top Kenwood unit and the leads to keep steering controls working.
I personally wanted a stereo with rear aux and usb out so I could put my usb stick out of sight and also look neater.
I also added a sub to the boot as I like the extra base. I changed all the door speakers to Kenwoods which came with the correct plug sockets so my exsisting wiring plugged straight in.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
Bandit12
- x 12
Hi Spikey I've got the same car as you and planned on getting this stereo for mine
http://www.amazon.co.uk/Pioneer-DEH-X35 ... escription" onclick="window.open(this.href);return false;
It looks like you have thought of everything and that is a very good website you have found to get the adaptors and faceplate. The only thing that might be a problem is retaining the existing cd multiplayer mounted under the drivers seat (if you have one) but as the stereo you are looking at lists 2 aux in ports you may be ok.
I recently took out my original citroen stereo to replace the fascia and took photos of the connections on the back. I can post them/PM them to you if you wish. Only thing I found with my citroen is that it had a major tantrum when I reconnected the battery! Lots of warning and error messages to do with the alarm, satnav, suspension etc. Had to leave it for 30 minutes with ignition off, then another 10 with ignition on but engine off before car settled down for me to be brave enough to turn the key!
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone)
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade)
Bandit12
- x 12
forgot to add that it looks like you will also need this adaptor as well as the one listed on your original post
http://www.caraudiodirect.co.uk/ct20ct0 ... 4-c5-c6-c8" onclick="window.open(this.href);return false;
Probably worth contacting them to confirm though
cpikey316_
Isn't that for cars after 2004?Bandit12 wrote:forgot to add that it looks like you will also need this adaptor as well as the one listed on your original post
Bandit12
- x 12
Yes it does look like its for cars after 2004-my bad and didnt read that bit properly:-). What I did notice was that the stalk adaptor says
"The adaptor consists of two parts, these must both be purchased based on your vehicle model and choice of radio brand" Which implies to me that another adaptor is needed which also tallies with the number, size and colour of all the connectors found on teh back of the standard stereo unit. Best thing would be to contact them and confirm
cpikey316_
The HU comes with a lead of some sort, hopefully its that one. If not, itll be down to halfords for me!!Bandit12 wrote:Yes it does look like its for cars after 2004-my bad and didnt read that bit properly:-). What I did notice was that the stalk adaptor says
cpikey316_
UPDATE!
Back to Halfords anyway, they've given me a returned example with no Mic kit!
On a useful note, where do we recommend mounting the mic and ow can I route the cable there?
Bandit12
- x 12
Halfords strike again!
Daft question but what is a Mic kit?
SaabC5
Probably has bluetooth phone integration so you need the mic to talk into. Most people route the wiring up the a pillar and across to the interior light/rear view mirror position.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
cpikey316_
Interesting thought, I was thinking about just attaching it to the A pillar at the top. Is this a bad place for it to be?SaabC5 wrote:Probably has bluetooth phone integration so you need the mic to talk into. Most people route the wiring up the a pillar and across to the interior light/rear view mirror position.
jgra1
- (Donor 2021)
- x 37
sorry to hijack..
If anyone knows of a Bluetooth and also DAB stereo that will fit a c5, and retain the remote control and possibly some of the display can you let me know?
John
John
