c5 2002 2.0 hdi manual gearbox problem
tiberian
Unread post by tiberian »
hi guys i rearly hope you can help today i changed the starter motor and battery hopeing to cure the poor starting on the old girl but no still the same ,i got it started with a squirt of quick start and went for a run, however on the way up the street my 3rd gear dont engage no crunching nothing it just revs as if in neutral ,is it possible i have knocked of a wire or something any help would be great thank you.
x 1239
Re: c5 2002 2.0 hdi manual gearbox problem
Unread post by Peter.N. »
If its the same box as the 406 uses the ferules on the gear lever end of the cable come loose, so as you try and put it into gear it pushes the whole cable out instead of just the centre, the cure is to crimp them with a pair of mole grips.
tiberian
thank you for your reply peter are the ferules under the car or in it i hope this dont sound too dumb thanx again for your help
x 1239
Just follow the gear change cables back to below the gear lever and you will find them.
tiberian
ok mate i will have a look this morning fingers crossed eh
tiberian
ok got the car up just looking under where the gear lever comes out it is completly concieled by a long ali muck and heat shield just gonna take this off think i have to unbolt eahaust as well or maybe only the front bracket
tiberian
i got the heat shield off what a pig it would be so easy without the exhaust in the way god only knows if it will ever go back on lol, anyway i can see the box now and where the cables go in does anyone know how to get in it
tiberian
ok guys i am begining to get that sinking feeling there is nothing wrong with the cables or ferules any more ideas anyone
Xantidote
x 5
Unread post by Xantidote »
tiberian wrote:any more ideas anyone
I'm not au-fait with the C5 and the gearbox cables, but was it just 3rd gear? What about 4th & 5th. Does it still drive OK some gears?
Martin
tiberian
yes all other gears are ok and car drives perfect just no third gear
tiberian
i think this could be an internal gearbox failure what do you chaps think
x 1239
Possible but unlikely I would have thought.
tiberian
are there any alternatives nobody seems to have any idea unless its a secret lol
tiberian
are the cables adjustable or is there any adjustment on the gearbox end
x 1239
Does it feel as though its going into gear but nothing is happening or is there no resistance when you move the gear lever?
