Need my nuts removing
ej2095
Unread post by ej2095 »
Hi all
Have a C5 Citrion 2001 model
How ever i dont have a wheel lock nut thingy to remove the lock nuts..
Citrion said they want 50 plus vat for it....
Case of wtf..
So does one know of a way to get these things removed....
This is one that i found in the spare tyre when i came to locate the nut thingy
so any help please
C5 2.2 HDI Estate mk1 (With a anti theft fury dice device)
Stewart(oily)
x 35
Re: Need my nuts removing
Unread post by Stewart(oily) »
Tyre depots have a kind of tapered spline socket that in conjunction with an impact wrench makes short work of them.
qprdude
x 14
Unread post by qprdude »
Yep, try a tyre depot, then replace the locking nuts with ordinary ones.
Sorry, but these day's nobody wants to nick a 12 year old car wheel.
Rick.
2013 Citroen DS 5 D/Sport
x 94
Unread post by citronut »
or try the likes of these
https://www.google.co.uk/#q=locking+whe ... l&tbm=shop" onclick="window.open(this.href);return false;
the other option is two bricks :yikes: :shock: :twisted: :roll: :wink:
you just have to watch your thumbs :rofl2: :-D :wink:
Regards, malcolm.
x 1240
Unread post by Peter.N. »
..or weld a nut onto it.
daviemck2006
x 496
Unread post by daviemck2006 »
Tried all these things on my dear departed c5 with no joy. The outer bit of the bolt which guides the extractor on breaks off, leaving a worse problem. My only solution was a Good going electric drill, quite a few drill bits and lots of swear words. X4. These kind of lockers are the most despicable things I have ever seen, with maybe the exception of the ex wife. Drill them out, chuck them and replace. Much the same as wifes really :shock: :rofl2: :rofl2: :rofl2:
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
qprdude
x 14
Are these nuts or studs?
Rick.
ej2095
studs
qprdude
x 14
Ah, OK. Wondered how Davie could drill out a nut.
Rick.
waynedance
x 8
Unread post by waynedance »
First thing I remove from my cars are the locking nuts.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
x 2941
When I had this problem I took it to my local tyre shop and they had them all off in less than ten minutes, not charged a penny, a special tool and a lump hammer did the trick.
x 94
ej2095 wrote:studs
they are bolts actually :roll: :-D :rofl2: :wink:
but sounds like David has had experience of nuts also :shock: :twisted: :yikes: :-D :wink:
Regards, malcolm.
ej2095
local tyre place by me are crap...
any recommadations near the dudley/tipton area in teh midlands
bonnyman750
x 3
Unread post by bonnyman750 »
I had 2 out of the four pins broken on the locking nut for my C5 X7 Tourer and I only found out when trying to remove the wheels for brake checking soon after purchase. My solution was to hacksaw 2 short pieces off the shank of a 4mm drill the same length of the remaining pins, jam them into the nut holes and use an impact driver to remove the locking nuts. It took a few blows on each nut but eventually they came out...
I have to confess I did purchase a new genuine set of locking nuts from my local dealership (where the car came from originally) at £50 but I made sure that they were well copaslipped before fitting and were done up with a torque wrench to the correct torque (force of habit after working in the automotive test environment!!). I will take these off before going anywhere near a tyre fitting bay...windy guns eat these type of locking nuts for breakfast, breaking pins and deforming the corresponding cutaways on the locking bolt (just like Discovery/Freelander ones used to :evil: )...
HTH
Glyn
ej2095
got 3 off... last one as always being a sod... BUT i go the one off i needed to as tyre was looking a tad dangerous
