V6 Xantia......... the beginning of another adventure
Trainman
(Donor 2018)
x 43
Re: V6 Xantia......... the beginning of another adventure
Unread post by Trainman »
Cool, I've told Andrew he can have it if he wants it, if not then I'll get it sorted and put away, I only actually want the pads and discs, the rest of the stuff can go on one side until it's needed......
Steve
http://c6owners.org/index.php
DHallworth
x 163
Unread post by DHallworth »
Just to clarify, you cannot force a multipoint LPG car to start on LPG. A single point car you can, but not multipoint.
Also, if you've got coolant anywhere near the LPG injectors you've got problems ;) The coolant should only be at the vaporiser where it uses the heat to turn the gas into a vapour from it's natural liquid state.
That bad strut top is well knackered! You still chasing all the little faults on yours Steve?
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
KP
x 27
Unread post by KP »
When the other side came off I was surprised it hadn't already speared the bonnet as it crumbles in your hand almost :(
But the other gubbins that are there should see you well for a while as I'm sure it was mentioned it had had replacement front bearings in the last few years and the discs and pads are plenty meaty with decent enough calipers but having them already stripped off the car it would be best to strip them and fit a new seal kit from brakesint and get the full benefit of you ever had to swap them :)
Trainman
(Donor 2018)
x 43
I was hoping fit the discs and pads this weekend, but I'm not likely to have the time to do that, until after Christmas if I Can't get it done on Tuesday.
I'm going to take the struts with me to the technical day at Graham Morton's on Sunday in the hope I have the opportunity to strip them down ready for me having a bash at them next week. Before I have a bash at doing the rears, the other option is to get somebody else to do it, and put some money in their pocket.
Steve
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Before starting any work on the rear struts start soaking the rear R clip on thd end of each strut in penetrating oil .. otherwise they will never come out and nothing will get done.. douse them once every other day if you can steve...
A very sad...
1994 XM 2.1 d auto
Trainman
(Donor 2018)
x 43
Well, I've loaded the Xantia for the Northern Section technical day tomorrow, thought I'd throw the struts in the boot in the hope of getting the bits stripped off I need and get them broken down into more manageable pieces, remove the strut top, disc's, pad's caliper's, etc that way I can store them more easily. There's no way I'm going to get them replaced before Christmas, I just don't have the time.....
The hole in the dashboard is no more thanks to Malcolm (Citronut) for supplying me with a recovered unit, He's also graciously sent me a recovered switch for the boot light, which I'm hoping to do tomorrow as well........ [-o<
Steve
citroenxm
Fallen Hero
x 70
Im sure the boot light does not work from the moving plate around the boot catch.. i think thats for the alarm. I could be wrong though..
Weather atroshious here today gales and wet going your way..
A very sad...
1994 XM 2.1 d auto
Trainman
(Donor 2018)
x 43
citroenxm wrote:Im sure the boot light does not work from the moving plate around the boot catch.. i think thats for the alarm. I could be wrong though..
No it's a little white plastic thing with a ball bearing inside that fits in the tailgate
citroenxm wrote:Weather atroshious here today gales and wet going your way..
I NO WANT !!! You can that sort of weather................ :rofl2:
Steve
citroenxm
Fallen Hero
x 70
I thought as much steve, thanks for conformation!
A very sad...
1994 XM 2.1 d auto
x 8294
I like your new festive avatar Steve :-D
The little black switch in the boot hasp is for the alarm and Hydractive switching. It can go iffy and be responsible for intermittent alarm activates and also for mysterious battery discharges because the Hydractive system remains largely in soft mode with the electrovalves activated. The total of nearly 3 amps they draw soon pulls the battery down..
citroenxm
Fallen Hero
x 70
CitroJim wrote:I like your new festive avatar Steve :-D
Shouldn't it be leaves on the line, or more so Water and Rocks (North Wales Line last week resulting in a closure) in stead????
When do we get snow!
A very sad...
1994 XM 2.1 d auto
x 8294
citroenxm wrote: When do we get snow!
In the New Year Paul :wink:
This is a good, normal winter so far. Fairly mild but damp and gloomy running up to Christmas and then hopefully cold, frosty and bright thereafter until spring..
Then we'll be in for a lovely summer :-D
KP
x 27
Unread post by KP »
Sorry I did mean the vapouriser :)
However unknown of at least 1 multi point system that let's you start on gas ;) I have no experience with single point systems but when you get a month down the line and haven't put a drop of petrol in the tank and the needle still reads dead on 1/4 full after being force started on LPG all the time it makes a difference :) mind you my commute to and from work was 4-5miles each way it soon adds up doing it that way :)
Trainman
(Donor 2018)
x 43
citroenxm wrote:Shouldn't it be leaves on the line, or more so Water and Rocks (North Wales Line last week resulting in a closure) in stead????
This was the sea wall at Mostyn the North Wales Coast
I'm not sure where this one was taken, I know it was along the same line, as you can see it was rather damp
This one was in Scotland
Steve
citroenxm
Fallen Hero
x 70
The North Wales coast ones were all between Rhyl and Talacre low lying line...
A very sad...
1994 XM 2.1 d auto
