Noisey Tyres
martscar
Noisey Tyres
Just replaced my 2 front tyres with a pair of Dunlop Blueresponse. I found them really noisy to the point that I have now swapped them for the slightly worn back tyres with a different tread pattern. At first I could not understand what had happened so went down the pit and checked the underside out to see if I had lost a panel, thats how pronounced it is. Anybody know of a good quiet tyre please
evilally
- x 3
Re: Noisey Tyres
Just fitted a set of Goodyear Eagle F1 Asymmetric 2's to the Clio. Apart from being possibly the best tyre I've used, the ride is smoother and they're a lot quieter than the Pilot Exaltos that they replaced
'96 405 1.6 GLX with 306 GTI engine on Cat cams @ 195bhp
'05 RenaultSport Clio 182 Cup, 102k
'97 406 1.9TD, 314k.
martscar
Re: Noisey Tyres
There must be a guide somewhere, I have had a look round but there doesn't seem to be anything apart from the manufacturers blurb
martscar
Re: Noisey Tyres
I am gona make a list any that are recommended ,so thanks for that
Citroenmad
- x 110
Re: Noisey Tyres
I've always been impressed with the quietness of Dunlop tyres, I did use some SP2000 Dunlops one one car which I would class as a budget tyre, but other models have been good.
Your Blueresponse tyres get one of the lowest measures of speed for any current tyre. 68dB it is rated at and for grip and efficiency, they are also very good. If the reviews are to be believed:
http://www.valuetyres.co.uk/tyre/brand/ ... R/id/14836" onclick="window.open(this.href);return false;
Maybe they will be better once they have scrubbed in a little.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
martscar
Re: Noisey Tyres
Maybe but previous versions were good straight out of the box so........
- x 2007
Re: Noisey Tyres
silly question....but are they Uni-Directional ? and are they fitted the correct way round on the hubs ?
martscar
Re: Noisey Tyres
A very good point, not had a chance to check but I will,thanks
isisalar
- x 3
Re: Noisey Tyres
Was checking out the price of tyres recently and it would seem they are all now rated for noise level as well as speed etc. Probably about as accurate as fuel consumption figures but it's somewhere to start.
Cheers
Paul
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
