Xantia clutch replacement by dropping end of engine down?
romie
Xantia clutch replacement by dropping end of engine down - D
Unread post by romie »
DONE!
Thanks very much for all help guys.
Along with clutch I also replaced all these parts that was suggested in this post along with replacement oil!
Fork release pin came out very easily (thank goodness).
Just to note:
I only needed to pull both drive shafts out of gearbox and tie them back out of the way instead of removing altogether :)
Superb. Went without a hitch and clutch is now ten times lighter and without any grabbing or juddering. Left knee will survive another few hundred thousand miles.
Cheers! :D
Citroen Xantia 1.9TD 1996 estate 100% veg 323k
Ford Transit Tourneo 2.5L Di 1999 165k
Yamaha R1 1999 26k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 1992 x 2
Mountain bike, skateboards, snowboards, surfboard, longboard and feet!
jgra1
(Donor 2021)
x 36
Re: Xantia clutch replacement by dropping end of engine down
Unread post by jgra1 »
good work Romie ;)
x 94
Unread post by citronut »
romie wrote: Just to note:
good to hear its sorted,
although i would think if the O/S CV joint is still attached/fitted to the hub, this would make it very difficult to drift the intermediate bearing out of its housing,
so i would still prefer to remove that one at least
Regards, malcolm.
flying clutchman
x 3
Unread post by flying clutchman »
I normally leave the o/s shaft in the hub, it doean't make knocking the intermeadiate bearing out any more difficult, but I always take the n/s shaft right out to give more room. Whatever makes you happy I suppose!
romie
Cheers!
I did have the advantage of being able to do it over two full days, (embarrassed face).
Very low stress with ample tea breaks :D
Once the drive shaft was clear of the intermediate bearing housing, I did use a ratchet strap hooked to the centre door pillar allowing me to pull the rhs hub and drive shaft a full inch! clear of the diff :D
Yamaha R1 1999 26k
CGATCX25GTITURBO
x 15
Unread post by CGATCX25GTITURBO »
for 10 mins of work I take the shafts out :)
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
