How Long do have left With my Slipping Clutch
CGATCX25GTITURBO
x 15
Re: How Long do have left With my Slipping Clutch
Unread post by CGATCX25GTITURBO »
flying clutchman wrote:
Richard_C wrote:Have you looked at dealer prices? On Citroen.co.uk under owner services you will find some fixed price deals for older cars. Not all dealers participate but if there is a good one near you that does you might find it less than, a non dealer.
Supremely optimistic! I've never come accross a main dealer who will do a clutch on ANY vehicle for a reasonable price. It's just not in their DNA. When they hear the word clutch they think you've just told them to rebuild the car.
When I was looking to have a Xantia clutch done the specialist price was around 300 and the main agent wanted 399, not too far off the mark.
I have a Picasso with a DMF, it's been chirping for a while now (years) I'll swap it when it starts juddering. It's got 80k plus on it and I'll be replacing it like for like, leaving it standard :)
Neil aka CGAT
1986 CX25 GTI TURBO 1 SERIES 2 'CGAT'
1998 XANTIA 19TD ESTATE
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
1989 CX GTI Turbo 62k miles in a barn since 2001, project started 2023.
flying clutchman
x 3
Unread post by flying clutchman »
I refer you to the financial interest comment! Direct injection engines are inherently harsher than prevoius generation diesels, hence the need for damping
Citroenmad
x 110
Unread post by Citroenmad »
RichardW wrote:The original 2.0 8V HDi is OK with a solid flywheel - the Xantia never had a DMF.....
Yes, very true.
I wouldn't ever put a DMF back into a 2.0HDi 8v (you don't have any choice with the others), they are designed to fail in my opinion and the costs are just the extra kick in the teeth. We have never had to change a clutch in any car until we started driving cars with DMFs. We have had two DMFs fail, both cars had a very meaty friction plate still and one car had only 25,000 miles on the clock. So you can understand my annoyance with them. As said, the 2.0HDi 8v is fine with the conversion kit as it was designed to run with a solid flywheel.
Our 2.0HDi 110 C5 has a solid flywheel, it was put in at 60K miles when the original DMF gave up. Its done 100K on the solid coversion and its still fine. The only difference I can tell between that and other 2.0HDi 8vs which have a solid flywheel is the bite is a bit higher. However, no vibrations or ill effects. Our car is also used to tow a horsebox and its peace of mind the DMF isn't there to fail again.
No brainer. :)
However, I would be very careful about fitting a conversion kit to other engines not designed to be without it. My experience with our C5 says the 2.0HDi 8v is fine for conversion.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 1238
Unread post by Peter.N. »
Did you find the Hdi smoother with the solid flywheel Chris?
x 94
Unread post by citronut »
CGATCX25GTITURBO wrote: I have a Picasso with a DMF, it's been chirping for a while now (years) I'll swap it when it starts juddering. It's got 80k plus on it and I'll be replacing it like for like, leaving it standard :)
but Neil
the bodywork on your pi*s*c*s*ooooo is melting away :yikes: :-D :wink:, so by the time you do the clutch you will probably be able to get straight at the gear box
Regards, malcolm.
CGATCX25GTITURBO
x 15
but Neil
Nooo, shes all better now, jobs a good one; going to set about the belts soon.
Neil aka CGAT
1987 BX19 GTI 8V
2012 Citroen DS3
1997 600 Bandit
2000 ZX12R from new
