Radio removal on an AX
Mark W
Unread post by Mark W »
Anyone know how I remove a modernish radio/casette unit from the dash of my 1992 vintage AX Echo. Do I need any special tools or does it just pull out?
Mark W
Stuart McB
Unread post by Stuart McB »
Think it may be held in by just the usual way. Or if any thing only a couple of screws. I'm lead to belive thoe that on some of the newer (now older) AX's you have to remove the ends of the unit to reveal the fixings.
Jiff Lemon
Unread post by Jiff Lemon »
You need to slide a thin flat screwdriver or similar, roughly in the middle of each side and press both sides in.
gardenpeas
Unread post by gardenpeas »
this job is a major pain in the backside be careful not to scratch the plastic suround maybe put some tape over the dash part to stop it being scratched
