Well Taffy, when you do an ECU swap, you will NEED the Body computer to go with it! (IMPORTANT!)
You then have a choice, Lexia to match your exisiting key to the replaced ECU, or get a full matched set, in which you will need to swap your ignition barrell..
Ive got a full set with matching key here im sure.
2.0 hdi xantia won't fire
citroenxm
- Fallen Hero
- x 70
Re: 2.0 hdi xantia won't fire
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
taffy
well hopefully il have a lexia plugged into it tommorrow but if alls not well then could be ecu transplant
p0191 is fuel pressure sensor malfuntion
there are other codes for pressure to high/low inconsistant...
gona have a final check of wiring to maf morrow
gona be so gutted if it is ecu
might have to take u up on that paul
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
harryp
- x 74
Been reading this extensive post with interest, so please excuse the intrusion. I had a similar problem and bought a new battery which improved things only marginally. What really got it going was a new positive battery lead. It is now running on a 7 year old battery that has been sitting unloved in the garage for about 2 years and only recently charged. Have you checked the volt drop from the battery post to the starter motor under load? (volt meter connected across). BTW, am not really expecting it to start readily when it gets to well below 0C, but it starts in one revolution at the moment at 5C. HTH?
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
taffy
yea ur more than welcome harry
well good point mate i will have a look tomorrow
on full charge my rpm is 250
prob getting about 50-60 turns out of the batt and i give up
seams to turn over well
this could be even an injector thou really hope mike is coming tommorrow with his lexia or dont know wat im gona do
im half in mind of getting a 1.9lx and swapping the exclu stuff over
without a lexia i cant do nothing ive lernt over the years with the 1.9
love my car so much but shes really breaking me down now...been off the road nr two months and before that another two months!
ive lost loads of work and jobs cause of this
harryp
- x 74
Hope you soon get it sorted Taffy. Sorry to hear it is affecting your income too. Good luck for today with the Lexia session. The lead is a long shot, but an easy one to check, mind you 250 rpm sounds like no problem in that area. Take care.
Regards, Harry
taffy
well no lexia today
so just gona go and see what i can find
thanks mate
thanks mate
Northern_Mike
Sorry Taffy, as I said in my PM, I'll have a trundle down when I'm a bit less sore! Won't be long..taffy wrote:well no lexia today
thanks mate
taffy
its ok mate id rather u get better
thanks
thanks
taffy
took injector out today and repositioned it so i could see if it was leaking and was no leek or spray...but what i did notice is surely the engine should spin over faster with the lack of compresiion but it didnt....strange?
taffy
wonder if it is battery or starter????
taffy
im not brave enough to try bump start it incase it dont stop lol!
taffy
well having a look at starter motors...few different ones
from what i can see they range from 1.4kw to 1.7kw....mitchibushi seems the best one with four brushs on the motor...was trying to look for some tech info on them but cant find none really...as to the rpm of the motors so i could work out what the rpm should be on cranking with good battery...
taffy
well mines a valeo d7r26
stripped it down and cleaned it....brushes are nearly dead but im happy there is a good connection there now
cleaning up the earths ad see wat happens
Timmo
- x 168
before swapping out the starter, its possibly worth the old Relay in the circuit mod, for the sake of a tenner in parts, eliminates the tired wires, does allow the starter to run at Full voltage too, worked a treat on my BX (running a Xantia td starter) and on a friends old td sinker xant,
(old starter feed to the relay, new feed form the relay to the starter, power and earth)
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
taffy
so basically run the starter wire to a relay and give its a fresh 12v supply...does it mater what relay to use?
thanks for the advice
