Citroen C5 spotlights not working
osx
(Donor 2022)
x 15
Unread post by osx »
Trying to find out why the two spotlights don't switch on. According to the manual they do not work when the car is in economy mode but they don't seem to work even when the engine is on and running. Checked fuse (although unlikely as I assume it should be the same fuse for all the interior lights) and bulbs - again no problem. Unfortunately did not have the amperometer with me to check the cables but could not see any cuts or kinks.
Any ideas?
It's a C5 Mk2
C5 X7 Exclusive 2.0 HDi Auto
x 1996
Re: Citroen C5 spotlights not working
Unread post by Stickyfinger »
Silly question, your not trying them with main beam on are you....mine go off as per regulation when on Main Beam
micky707
Unread post by micky707 »
:rofl2: :rofl2:
Micky
Citroen C5 2.0 HDI VTR 138 48k
Citroen Xsara 1.6SX Brilliant car, 9 years and 119000 Miles
2 Pug 306's
Peugeot 207 1.4 Sport
Citroen ZX 1.9D
If it aint broke.......
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
osx,are you talking about fog lights?
what sticky said, will only come on when on dipped beam .
John
osx
(Donor 2022)
x 15
Interior lights.
x 5672
Which fuse did you check?
Mine never worked until recently. Discovered it was the fuse for the forward fag lighter. Can't remember which one exactly but in the fusebox in the driver's cubby.
osx
(Donor 2022)
x 15
myglaren wrote:Which fuse did you check?
Will have a look
Link to the manual
http://launcestoncarhire.com/wp-content ... s-Handbook" onclick="window.open(this.href);return false;
fuses at p. 156-160
PS
Found it
F9 30A Cigar-lighter - Front 12V socket
Socket works fine so not that one
jgra1
(Donor 2021)
x 36
:roll: :rofl2:
lol sorry ;)
VertVega
x 13
Unread post by VertVega »
osx wrote:It's a C5 Mk2
Do you mean C5 X7 (2008 - ) or C5 II (2004 - 2008) also called as phase 2?
The link you have given to C5 owner's manual is for C5 X7.
( http://launcestoncarhire.com/wp-content ... s-Handbook" onclick="window.open(this.href);return false; )
It would have been much easier in C5 case if it was called as C5 I, C5 II and C5 III :roll:
qprdude
x 14
Unread post by qprdude »
Yep, handbook for an X7.
As already said, front fogs will only work with dipped beam on UK cars. Anything else is illegal .
Only aftermarket boy-racer jobbies with a separate switch will work as nstand-alone.
Rick.
2013 Citroen DS 5 D/Sport
osx
(Donor 2022)
x 15
qprdude wrote:Yep, handbook for an X7.
Not talking about the fog lights.
It is a C5 X7
osx
(Donor 2022)
x 15
Can't make them work
vborovic
Locked user account
x 40
Unread post by vborovic »
Hope it won't be a too stupid question, but have they ever worked? If they have, maybe the light bulbs (W5W) gave out on you. I've had all ceiling light s replaced recently with Philips ones (6 bulbs in total), don't see the reason (if not for the fuse) it wouldn't work otherwise.
osx
(Donor 2022)
x 15
Bulbs tested and working at the central interior light.
x 5672
I found that the central light is on a different circuit. Mine always worked but the 'spotlights' didn't
