Hi Guys
How do I turn over my 2.0 HDI engine without starting it?
Is there something I need to disconnect?
Rob
C5 - Cranking engine without starting it
hamster99
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
jgra1
- (Donor 2021)
- x 36
Re: C5 - Cranking engine without starting it
must be quite a few things that would stop her starting, and are easy to get to,.,
someone will know
all else fails the main injector rail feed should do it, bit of a pain to get to though
someone will know
- x 1488
If you can get to it under the rear seat, unplug the low pressure fuel pump - assuming it's got one.
- x 1052
Easiest way is to unplug the camshaft position sensor, remember just about anything you disconnect to do this will log a fault code that should be cleared incase there is ant confusion with any future faults.
Jeff
Try taking the battery out of the keyfob....but put it back quickly in between turning the car over or it may need to be re-programmed.
Currently driving Citroen c5 2.0 HDI 51 Plate
Gingerposer
- x 6
Would it not be easier to pull the fuse for the fuel pump?
- x 1052
That wont stop the engine firing, the battery in the keyfob is only for the remote locking, not the immobiliser.Jeff wrote:Try taking the battery out of the keyfob....but put it back quickly in between turning the car over or it may need to be re-programmed.
You could however wrap the plastic part of the key in a few layers of tinfoil which will stop it firing.
It may not even have an electric fuel pump depending what HDi it is, probably still easier to either just unplug the camshaft sensor, easily accessible right at the top of the engine or shield the key with foil.Gingerposer wrote:Would it not be easier to pull the fuse for the fuel pump?
qprdude
- x 14
I'm interested to know why you want to spin the engine without starting. Just being nosey.
Rick.
2013 Citroen DS 5 D/Sport
Xantidote
- x 4
After doing an engine oil & filter change, I always disconnect the stop solenoid on my TD so that the engine will spin without firing up. I like to see the oil warning light go out before firing up, to make sure the new oil fliter, oilways & bearings are fully primed with the new oil.
Martin
1995 Xantia TDLX (deceased
hamster99
I have just changed the turbo and I want to make sure there is plenty of oil pushed through to the turbo shaft bearings before I actually start it.qprdude wrote:I'm interested to know why you want to spin the engine without starting. Just being nosey.
Rob
PS - one person's "nosey" is another person's "opportunity to learn something new"..........think I heard that on a management course once...!!!
taffy
yea i did it other day myself just diconecting tank pump under seat but if u look for the fuse that would be better
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
