Hi folks
Odd one here. I have noticed that when driving the Xant, I get this wind howl sound, especially around 50-60 mph. You can also hear gusts of wind hitting the car by the change in tone.Hard to say where its coming from but it appears to be worse when there are other people in the car! Maybe its just psychological! I assume maybe door seals are getting stiff and there are maybe small gaps causing it?
Has anyone else had this?
No water leaks that I can see.
Cheers
Alan
Xantia Estate - Howling Wind!
ecohouse1
- x 3
Re: Xantia Estate - Howling Wind!
No roof bars fitted!
addo
- Sara Watson's Stalker
- x 95
- x 1982
Northern_Mike
On my 1995 Estate it was the door seals.ecohouse1 wrote:Hi folks
Cheers
Alan
Sent from my GT-I9300 using Tapatalk 2
- x 8211
Indeed and most likely. The driver's one wears terribly. Also check all doors are fully closing against the seals and that you do not have the start of the well-known estate problem of the top hinge of the driver's door starting to separate from the A pillar..Northern_Mike wrote: On my 1995 Estate it was the door seals.
- x 1240
Get someone else in the car to pull each door inward hard when you have the noise, the noise should reduce when the appropriate one is pulled.
Northern_Mike
On mine, as Jim says, it was the drivers door seal. It'd sound like I hadn't shut the door properly it was so bad, much worse in the rain, it sounded like water was coming in.
addo
- x 95
- x 1240
Normally adjusting the door catch is enough unless the seal is disintegrating.
falling-out-with-my-car
- x 25
front Xantia door seals Stealers only £95 a pop
my old drivers door one is no longer viable but i have good passenger door and rear door seals
and may well be breaking my S2 estate up soon.
NO IVE CHANGED MY MIND NOW I'M KEEPING IT.
Last edited by falling-out-with-my-car on 17 Oct 2013, 14:24, edited 1 time in total.
ecohouse1
- x 3
Thanks for the advice. I will try the catch adjustment first, then maybe live with if it doesn't work! Cheers
