V6 Xantia......... the beginning of another adventure
Trainman
(Donor 2018)
x 43
Re: V6 Xantia......... the beginning of another adventure
Unread post by Trainman »
Having a rare day off today, so plan of attack is to replace the exhaust with the new one from Poland, and see if I can stop the LHM leak. There's a couple of other little things I want to do, such as strip the centre console out to find out why the the gear selector isn't lighting up, Paul has supplied me with another unit just in case it's something more serious than a bulb.
The last thing on the car then is to replace the ultrasonics (again supplied by Paul) as they go off for no reason.
Once that's been done, and Paul has some time, she's going over to Paul's to have the heater matrix done, whilst the dash is out, I'm planning on changing all the dashboard bulbs as there are a couple out, Has anybody put LED's in to replace the normal bulbs?
Steve
http://c6owners.org/index.php
Trainman
(Donor 2018)
x 43
Well, not quite as productive as I would have liked, but still something's achieved, the old exhaust has been replaced by a shiny new one..
I had a good look at the old one and it's no wonder it was 'grumbling' shaking the back box sounded like you were shaking maraca's :shock:
I also noticed that the centre pipe was missing a chunk from the flange where it connect's to the back box
As was inevitable, the clamps between the two flanges were to small for the pipe, so I ended up going and buying a couple :roll: once that was done, I decided to tackle the gearbox lights, I'd spoken to Jim at CXM and he said that he thought there was a prism inside, there isn't. Just a good old fashioned bulb, that was duly replaced and is working. Next on the list was the ultrasonics, and having swapped the driver's side first, tested it. No. still not working, replace the passenger side. No still not working.
So still got the LHM leak to do, I didn't want to do that today as SWMBO :dom: decided that we needed to go shopping...........
Rain then stopped play :twisted: :twisted: :twisted:
I'm hoping I can have a look at the leak tomorrow after work............we'll see :?
Steve
x 8422
I can't see the problem Steve. Years of life left in the old system. I mean, it's not holed is it?
Did you buy a couple of the Polish ones? Good value just to keep as a spare for later..
Be interesting to see how long the Polish ones last compared to OEM.
Trainman
(Donor 2018)
x 43
I've no plans to keep the old one Jim, our garage is already full so if anybody wants it they're more than welcome, just need to let me know before I bin it in the next couple of days.
Steve
x 8422
Steve. I was joking!! Too early in the morning I guess
The old one is 100% scrap...
Trainman
(Donor 2018)
x 43
Jim, I wouldn't be surprised if somebody wanted it............
But I suspect you're right.
Steve
KP
x 27
Unread post by KP »
Did the polish one include the cat as well?
Take it down the local metal recycling centre Steve and get some £ back :)
The only way I can see that polish one lasting as long as the original Jim is by sealing the outside with a heat proof lacquer and making sure the exhaust gets very hot every month or two to ensure no nasty acidic moisture sits in it for long :)
Trainman
(Donor 2018)
x 43
KP wrote:Did the polish one include the cat as well?
Actually I could do, didn't think of that :shock: :roll:
KP wrote:The only way I can see that polish one lasting as long as the original Jim is by sealing the outside with a heat proof lacquer and making sure the exhaust gets very hot every month or two to ensure no nasty acidic moisture sits in it for long :)
Centre pipe and back box, Will, as for getting hot. Well, there's no issue with that, it's my daily driver :lol:
Steve
bxzx16v
x 34
Unread post by bxzx16v »
The old exhaust was very crusty Steve , the old girl must be transformed now =D>
Mark
Trainman
(Donor 2018)
x 43
bxzx16v wrote:The old exhaust was very crusty Steve , the old girl must be transformed now =D>
Mark
She sure is Mark, I can actually hear the radio now \:D/
I managed to resolve the LHM leak yesterday, it turned out to be a return pipe in the Drivers side wheel arch, the rubber pipe had snapped off
so that was an easy fix. bleeding the system was a 'tad' harder as the only access you have to the bleed screw is from underneath, which of course you can't see :roll:
so, slowly getting through things, but I'm coming to a stop, shortly, otherwise Paul will have nothing to do........ :wink: Actually it's more a case of me getting out of my depth, and will need a life line........... :oops:
Steve
x 8422
Those leakage returns failing are a very common problem now Steve. One on a F fellow WFA'er's car and one nearly on my Activa..
Time to get more in stock methinks...
KP
x 27
Unread post by KP »
One on my c5 went as well and the clips are a bugger to get back on even with the right tool :(
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I got the CORRECT clip pliers, and NOW the strut clip is a doddle to close up!!
A very sad...
1994 XM 2.1 d auto
x 8422
citroenxm wrote:I got the CORRECT clip pliers, and NOW the strut clip is a doddle to close up!!
Cor yes, it makes a hell of a difference. It goes from being a cussworthy job where severe clip damage is a real risk to a job that takes seconds :-D
Those tools are worth every penny.
Trainman
(Donor 2018)
x 43
I've found some switches for the drivers seat from Peugeot that Paul and I may be able to "adapt" to fit my drivers http://www.ebay.co.uk/itm/330851159063? ... 1438.l2649" onclick="window.open(this.href);return false;
At £15 its worth a gamble [-o<
Steve
