Xantia air bag light
- x 1431
The air bag light on the Xantia is coming on occasionally (it's an early one with the light on the wheel). It seems sporadic, staying on for a couple of seconds at a time. I guess it's probably one of the seat belt jobbies, but when this happened on my colleague's Saxo, the light would flash for a while, then stay on until you turned off then on again. Any thoughts? Does the ECU store fault codes, and can you flash read them, or should I just find the fuse and pull it out.....?
Richard Gallagher
- x 1431
After a bit of investigation on the way home last night[;)] I have come to the conclusion it is related to turning the wheel, and the light comes on for about 2 seconds - I think what is happening is that the air bag is losing power, and then powering up again and going through the self check routine, hence the light is coming on. Not every turn of the wheel causes it though! I guess this means the clock spring (or whatever Citroen call it) is breaking down. Bet a new one of those is a pretty price....[}:)]
