(Yep can get the 138BHP 2.0 HDi which I bet do go well indeed).
Indeed sorry about that Steve...
V6 Xantia......... the beginning of another adventure
Citroening
- x 19
Trainman
- (Donor 2018)
- x 43
Re: V6 Xantia......... the beginning of another adventure
Paul, it's the way of the blog, they always go off at a tangent....
Steve
http://c6owners.org/index.php
Trainman
- (Donor 2018)
- x 43
Just been and ordered the matrix £77.00 plus VAT, I priced the switches for the drivers seat, two 'contact switches' which can be bought separate, which surprised me. Great I thought, nice and easy, lovely....... The price £151.00
Steve
KP
- x 27
Blooming heck can you not get used ones for that much or even a whole new interior?!?
Creepers that's shockingly pricey!
citroenxm
- Fallen Hero
- x 70
Cruise control work Steve???
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Trainman
- (Donor 2018)
- x 43
Nopecitroenxm wrote:Cruise control work Steve???
Still, it would have been nice to getting working but there again you did only have a quick look. There's always next time.
Steve
KP
- x 27
Did you get home ok Steve as I had to drop off for fuel and then caught up but lost you again
I can't thank you enough for taking me over today, it was greatly appreciated
Trainman
- (Donor 2018)
- x 43
I did Will, I had to stop at three places before I got LPG and then had to pull over to top up the LHM otherwise a good run, going over to my dad's later to "borrow" his rampsKP wrote:Did you get home ok Steve as I had to drop off for fuel and then caught up but lost you again
Steve
Trainman
- (Donor 2018)
- x 43
Well, the Xantia decided to throw me another curve ball this morning
started her up and set off to work, got just round the corner and the water temperature light and STOP light came on, I pulled over and checked the water it was full. strange
....... anyway decided that the best thing to do was head home and leave it until tomorrow.
so where do i start
so where do i start
Steve
citroenxm
- Fallen Hero
- x 70
Cooling Fans Steve?
It can flash up when the cooling fans dont work, which are controlled by three relays, that sit between the fans in a little triangular box, behind the grill...
What useually happens is one or two of the connections to the relays corrode.. this then stops speed control or any feed to the fans. The Bitron control box senses this and throws the light on and STOP light.
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Trainman
- (Donor 2018)
- x 43
Hmm, fans were working..... even after I stopped the car, it's almost like it was over heating, BUT I could undo the radiator cap....
Steve
Trainman
- (Donor 2018)
- x 43
Right..... I took the Xantia for a run round the block, to try and find out what the problem was with the water light and STOP light coming on.
The round of he block is about a mile, now in that mile the water temp rose from zero to half of the normal running temp, when I got back home the cooling fans were running, I'm now wondering if it could be a faulty sensor or thermostat sticking
I can't see any loose or broken wires
Is there anything else I should be looking at
Steve
KP
- x 27
A sticky thermostat isn't good news
When it's stone cold start it up and see if the rad slowly warms up or gets hot very quick once the temp needle starts moving.
If it warms up slowly the stat is likely stuck open. If it warms up quickly when it is nearly at running temp the batty is opening and letting the water thru as it should.
Beyond that I don't know much about the v6 cooling systems I'm afraid
Chris570
- x 36
something to bear in mind is that the coolant probe is in the bottom hose and is pretty pants. I forget, do you have a Lexia? you can check the ECU coolant temp probe to see if it is giving similar readings....
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- x 8435
As Chris says, the gauge sender effectively reads the bottom hose temperature due to its location so about half of what might seem normal is right. They should under-read under normal running.
The thermostat in a V6 is normally reliable as it's not a conventional one. Good job as they're absolute sods to replace.
Good point Chris to use a Lexia to check the coolant temperature on the engine ECU. This sensor is in the normal place so reads top hose temperature.
The fault is likely to be electrical rather than an engine cooling problem and my first suspect would be the Bitron sensor. It's quite hard to get to and right under all the V6 cooling plumber's nightmare. The connector can get coolant dripping onto it which can cause a poor connection..
