C5 HDI - couple of things..
citroenxm
- Fallen Hero
- x 70
Re: C5 HDI - couple of things..
Sorry mike i didnt intend you to buy it but showed an example of price. Also had no idea there were different ones of these..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
OnlineHell Razor5543
- x 3306
Mike, have you tried Wokingham Car Spares (Bearwood Close, Winnersh)? I have seen C5s there in the past.
Northern_Mike
I haven't. I might have a look. Thanks.Hell Razor5543 wrote:Mike, have you tried Wokingham Car Spares (Bearwood Close, Winnersh)? I have seen C5s there in the past.
At the moment, I'm past caring.
addo
- Sara Watson's Stalker
- x 95
Northern_Mike
At least my Berlingo mostly works..apart from the mystery knock, which I believe is the left hand track-rod end.
You might know the answer to this actually - will the Comm 2000 from my 2002 C5 work for the main functions in the Berlingo? i.e. The airbag and horn?
I think the C5 SX Alloys will fit the Berlingo. They're 4 hole, but I'm not sure of PCD etc.
- x 1485
Mike
Post or PM the last 8 digits of the VIN of each and I can check on service.citroen.
addo
- x 95
Northern_Mike
C5 - 76139585RichardW wrote:Mike
Berlingo - 93184623
thanks for your help Richard.
Northern_Mike
Re:
Thanks Addo. I guess the 195s won't foul anything either being only 10mm wider.addo wrote:Wheels should be bang on. Not sure of the COMM unit.
Odd knock I found on the nearside recently was a completely duff inner CV joint. Deceptive.
COMM unit. Hateful things. Needs must. I'd rather it fits and saves me a few quid. I'm not bothered if the cruise doesn't work.
I could even put the intercooler, turbo, manifold, pipes etc on the Berlingo before remapping it.
CV joint? Curious. This noise is an intermittent knock, which I only hear when turning right at slow speed, or setting off from a junction. Sometimes. It's worse if there's a passenger. It's a dull, distant knock from the left hand corner. No noise at all when charging down an undulating country lane at 50-60mph bouncing up and down or hard cornering. Not a sound.
- x 1485
Don't think it's a go-er Mike....
C5: 624263
Berlingo: 6239CWQ replaced by 96787362XT
There doesn't seem to be any cross over of those part numbers between the Berlingo and C5 so I suspect it won't fit. Only one way to find out thought....
C5: 624263
Northern_Mike
citroenxm wrote:Sorry mike i didnt intend you to buy it but showed an example of price. Also had no idea there were different ones of these..
That's ok mate. Neither did I..
Anyway, kudos to VRS Salvage, a helpful friendly bunch, who refunded my payment immediately when I explained my cock-up.
Sent from my GT-I9300 using Tapatalk 4
Northern_Mike
No longer!addo wrote:And the Berlingo forum is down...
Northern_Mike
Oh Buggeration. Thanks for looking anyway Richard! The wheels will still fit it.RichardW wrote:Don't think it's a go-er Mike....![]()
C5: 624263
Anyone need any C5 parts? ....
isisalar
- x 3
These guys are a very helpful Citroen breakers, in Billericay.
:-http://www.edwardsandson.co.uk/
Cheers
Paul
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
Northern_Mike
Well seeing as it won't even start this morning.... I guess the rev counter failing yesterday was a sign of electrical maladies..
