C5 HDI - couple of things..
citroenxm
Fallen Hero
x 70
Re: C5 HDI - couple of things..
Unread post by citroenxm »
Sorry mike i didnt intend you to buy it but showed an example of price. Also had no idea there were different ones of these..
A very sad...
1994 XM 2.1 d auto
x 3306
Mike, have you tried Wokingham Car Spares (Bearwood Close, Winnersh)? I have seen C5s there in the past.
Northern_Mike
Hell Razor5543 wrote:Mike, have you tried Wokingham Car Spares (Bearwood Close, Winnersh)? I have seen C5s there in the past.
I haven't. I might have a look. Thanks.
At the moment, I'm past caring.
addo
Sara Watson's Stalker
x 95
Unread post by addo »
And the Berlingo forum is down...
Northern_Mike
At least my Berlingo mostly works..apart from the mystery knock, which I believe is the left hand track-rod end.
You might know the answer to this actually - will the Comm 2000 from my 2002 C5 work for the main functions in the Berlingo? i.e. The airbag and horn?
I think the C5 SX Alloys will fit the Berlingo. They're 4 hole, but I'm not sure of PCD etc.
x 1485
Mike
Post or PM the last 8 digits of the VIN of each and I can check on service.citroen.
addo
x 95
Wheels should be bang on. Not sure of the COMM unit.
Odd knock I found on the nearside recently was a completely duff inner CV joint. Deceptive.
Northern_Mike
RichardW wrote:Mike
C5 - 76139585
Berlingo - 93184623
thanks for your help Richard.
Northern_Mike
Re:
addo wrote:Wheels should be bang on. Not sure of the COMM unit.
Thanks Addo. I guess the 195s won't foul anything either being only 10mm wider.
COMM unit. Hateful things. Needs must. I'd rather it fits and saves me a few quid. I'm not bothered if the cruise doesn't work.
I could even put the intercooler, turbo, manifold, pipes etc on the Berlingo before remapping it.
CV joint? Curious. This noise is an intermittent knock, which I only hear when turning right at slow speed, or setting off from a junction. Sometimes. It's worse if there's a passenger. It's a dull, distant knock from the left hand corner. No noise at all when charging down an undulating country lane at 50-60mph bouncing up and down or hard cornering. Not a sound.
x 1485
Don't think it's a go-er Mike.... :x
C5: 624263
Berlingo: 6239CWQ replaced by 96787362XT
There doesn't seem to be any cross over of those part numbers between the Berlingo and C5 so I suspect it won't fit. Only one way to find out thought.... :roll:
Northern_Mike
citroenxm wrote:Sorry mike i didnt intend you to buy it but showed an example of price. Also had no idea there were different ones of these..
That's ok mate. Neither did I..
Anyway, kudos to VRS Salvage, a helpful friendly bunch, who refunded my payment immediately when I explained my cock-up.
Sent from my GT-I9300 using Tapatalk 4
Northern_Mike
addo wrote:And the Berlingo forum is down...
No longer!
Northern_Mike
RichardW wrote:Don't think it's a go-er Mike.... :x
C5: 624263
Oh Buggeration. Thanks for looking anyway Richard! The wheels will still fit it.
Anyone need any C5 parts? ....
isisalar
x 3
Unread post by isisalar »
These guys are a very helpful Citroen breakers, in Billericay.
:-http://www.edwardsandson.co.uk/
Cheers
Paul
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
Northern_Mike
Well seeing as it won't even start this morning.... I guess the rev counter failing yesterday was a sign of electrical maladies..
