Berlingo 1.9d died while driving
Penev
Unread post by Penev »
Hi to everyone :)
I have this Berlingo 1.9d that died while driving. I did a timing belt two months ago and had no issues until now. There is fuel to the injectors, I am nor sure how strong the pressure should be. I changed the glowplug relay - same thing. I was wondering if any of you have some advice for me :)
Thank you in advance, I will keep you posted :)
Ivan Penev :)
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Have you checked the timing belt since it stopped running?
Does the engine start with a spray of ether or WD-40?
Penev
Re: Berlingo 1.9d died while driving
I did, but just removed only one of the plastic covers. It seemed all good. I am going to take it all apart in a minute to double check the timing. I was looking for a way to check the timing without taking it apart, like the regular engines (not diesel), but could not find such method :)
x 94
Unread post by citronut »
you only need gain access to the cam and pump sprockets to peg them off, then peg the crank off via the hole in the crank case behind the starter motor
Regards, malcolm.
Penev
hi again:)
The timing is perfect, the belt is perfect and all that part. I actually took it apart again. I tested if there is diesel to the injectors and there is. Then I tested if there is electrical pulse to the injectors, and in each injector there was only one pulse at the beginning of the crank, after that the starter kept turning the engine but there is no electrical impulse to the injectors, therefore there will not be any diesel in the cylinder. I am thinking that is crank shaft sensor, or computer issues. Has anybody had similar experience or have knowledge about that sensor :)
thanks
x 94
were are you located as there are some members on here that own DIS-LEXIA's,
you can find there location in the link below
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
if you are in the UK just select one near you and pm the owner
Regards, malcolm.
Penev
I am in Bulgaria, I do not thing there is one near by, thank you dough :)
Penev
I will get a diagnostic computer and I will keep you posted.
regards for now
spider
x 77
Unread post by spider »
I'd expect it to run though if the timing is right even without the needle sensor and tdc sensor it will run but very roughly. It is an electronic pump but the electronics can only adjust it so far, it should run in a fashion regardless.
I'm assuming its a DW8 as the XUD (non turbo) in this vehicle never had the needle sensor they changed to the DW8 around 99 instead.
If there is no fuel there the shutoff valve may of jammed closed (rare) or the wiring is suspect. Immobiliser is only checked during startup not when its actually running.
If possible check with a piece of clear pipe between filter and pump to ensure its not full of air too. Check EGR valve has not decided to stick open, although you'd normally have poor running first if this happened.
Andy.
Penev
You will not believe what came up from this vehicle, somehow it broke the camshaft ! Even with broken cam shaft the engine turned by hand and the timing belt is on the marks. I never expected that. I am still looking into it,I will keep you posted
Thanks to all that triad to help :)
Penev
Stewart(oily)
x 35
Unread post by Stewart(oily) »
Sounds like the cam belt has jumped, the cam snapping is normal when the cambelt breaks, yours may have been loose, check also for cracked bearing caps and bent studs.
spider
x 77
Ouch. :(
Was it in three pieces as the older XUD's did ? , I think the DW8 would probably do the same.
Andy.
Penev
The belt was on spot, it has did not jump or was loose. The shaft was broken in two pieces. It was changed and the car run better then before.
Xantidote
x 5
Unread post by Xantidote »
Glad to hear it's running again
Martin
