Help needed ... got a leak
x 5672
Re: Help needed ... got a leak
Mike,
there's an old-fashioned Citroen indy in Sunderland, George Fraser, Toward Road.
Note that his brother has a garage close by on Henry Street. Don't mix them up.
I used to take my Citroens and the kids have taken Peugeots and Renaults, always been satisfied. The only reason I haven't been there for a while is logistics centered around work.
As said, old school, no electronics, just mechanics and basic electrical stuff.
x 5672
superloopy wrote:Thanks Steve ... i never knew he was over there. Could sound him out for the work eh ... good to know there's still some expertise around.
Sent from my GT-N7100 using Tapatalk 2
You can always ask him Mike. He is a very nice bloke and painfully honest.
I have given him instructions before to "Just fix it" but he always phones and gets confirmation before incurring unforseen expenses and has been quite apologetic about the price of some parts - which is completely out of his control of course.
Here are his details if you do decide to contact him: G D Fraser.
Stewart(oily)
x 35
Unread post by Stewart(oily) »
Depends where the core plug is, I had one behind the fuel pump start leaking on a BX TZD. the tiny jet of coolant was squirting out, hitting the pump mounting plate, running down the block and around the engine under the cambelt covers to drip off right under the waterpump :) the new core plug was 28p and was leaking at a point on the edge but was otherwise in great condition, with hindsight I should have dropped some sealant in there and forgotten about it, the waterpump, cambelt and arsing about before I located the leak was the biggest pain :)
some engines have them behind the flywheel :twisted:
x 8400
Mike, although there are no core plugs on the gearbox side of the head there is a complex water manifold (what our snail-eating friends call an outlet tank) that bolts onto the side and contains the thermostat, the sensors and the heater matrix take-off. I'd not be surprised if the gasket between the head proper and the manifold is not gone and causing the leak.
If you want, I'll take a picture of it later... It bolts onto the side of the head. I've looked in service.citroen.com but I can see no gasket.
Mike, I described how to remove the turbo tubes in an earlier post in this thread - just after you reported that you'd lost your rag, The black one is not too bad but the ally one is a lot of fun...
x 8400
Mike, here's a picture of the head and it's water manifold...
Please note that the rest of the engine and the car have been removed for clarity...
x 8400
Mike, If I have the time and energy tomorrow I'll whip the manifold off that head and see what lies beneath...
x 8400
Mike, I'm sorry. I ran out of time today. Firstly daughter's 207 shed a CV boot and then this afternoon I was involved in CXM work...
Wednesday is my next opportunity now...
All good wished with Activa No.2 Mike... The problem may well be the engine bay fuse box if the harness looks OK..
Chlorate
Unread post by Chlorate »
How chunky are your arms?
I'd probably try to endure a bit of pain with a little 1/4" ratchet handle a 7mm socket.
They don't half make these things awkward don't they...I remember the turbo hose on my ZX was held on with a similar jubilee clip.
Have a magnet on a stick or a wire coathanger to hand to retrieve the blasted thing.
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police :evil:
KennyW
x 165
Unread post by KennyW »
Mike,
Re the jub clip I had long flexible screw driver with 7mm hex for these jobs but typically I loaned to someone and not received it back. :x
Sealey catalogue have a similar tool VS0620, I'm sure Igot mine at Machine mart.
Kenny
C3 1.4 petrol (SWMBO)
x 1489
You need to make more room....
Take the engine out :lol:
You might get away with taking off the OS engine mount, and then pulling the engine forward away from the bulkhead - an extra inch might make all the difference, and with the mount out of the way you might be able to reach around the corner of the cambelt and get on it? Can't envisage which way it is pointing - could you go in via the wheel arch with a long extension?
x 94
Unread post by citronut »
if you feel the head is rounded off using a 7mm socket, try a 6mm as quite often citroen jubilee clip can have a 6mm head, which that certainly look like to me
Regards, malcolm.
oscar
x 8
Unread post by oscar »
If your stuck for an air pipe you can get thoose nice blue ones in silicone fit most things as can get ali joiners that come in many angles
what about those nut out sockets from Irwin to expansion set goes that low size i think it's a reverse splined ones that bite into heads also theres a set on flea bay that go from tiny to big some american brand? Xi-on http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0710275721" onclick="window.open(this.href);return false;
