C5 Colour Dislpay
2smv627
C5 Colour Dislpay
Unread post by 2smv627 »
Hi, I have a problem with my 52 C5 Excl SE in that the colour display is blank - doesn`t even light up.
I have tried another screen but this is also blank. The radio works but doesn`t always switch off with the ignition and after plugging into Lexia a couple of faults say no comms with the display.
1) Does the display need to be programmed to the car? I know the dot matrix ones work from car to car.
2) Is the problem most likely to be with the ECU fitted above the GPS drive?
Thanks in advance
x 1970
Re: C5 Colour Dislpay
Unread post by Stickyfinger »
Cant help with the problem.....however I do know (my now dead ex car) where there is a complete RT2 system incl working sat nav.....if you need them the car is in Dorset.
2smv627
Just an update, the problem was with the satnav/screen ECU.
Ended up buying another C5 estate, pinched the ECU from that and hey presto fully function screen.
Cheers
