Hi folks
I have a 51 reg c5 2.0 hdi 110 bhp ,drives fine but no power or oomph when accelerate hard eg going from slip road to motorway /dual carriageways
i have checked turbo and vaccuum pipes
all above fine
what else could it be?
Cheers folks
Gaz
C5 2.0 HDi 110 51 REG LOSS OF POWER
gazzas c5
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
Lighty
- x 34
Re: C5 2.0 HDi 110 51 REG LOSS OF POWER
Needs to go on a diagbox or Lexia machine, could be loads of things !
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- x 5676
Check the throttle cable for slack. They seem to stretch after a while and need adjusting up to achieve full power. Mine was complete rubbish until that and a few other tweaks were done.
The other thing that might cause it is the MAF, which generally doesn't throw up a fault code.
I presume that you have checked that the air filter is clean?
- x 2004
and DO NOT TOUCH it with ANYTHING
, only use a specialist spray cleaner....nothing else
citroenxm
- Fallen Hero
- x 70
Thats an interesting one about the MAF sensor on the air cleaner!
I had a new customer C5 car in, and he asked me to change the MAF sensor for one he had supplied.
Two days later he was on the phone, Engine light on, no ooompphhh, Though the car was not in Limp Mode. It just had no go.
Went today, swapped it back to the other one, all restored, better go, no engine light on.
However, would NOT of confirmed that without the Lexia though! So a C5 really needs a lexia to really see whats going on..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Joncarpet
Sorry to hijack the post, but i'm having the same sluggish lack of oomph.
I've got a 2002 2.0 HDI SX estate. It accelrates slowly. It drives fine. Until it gets to a hill. And then it struggles massively.
Its soo bad with hills that i often have to drop down into 2nd. Which is not good on the M62.
The accelerator pedal was about 2 inch lower the others, but read on here how to sort that. I tried to take the slack out of the accelerator cable but not sure ive done it right.
Standing at the front of the car, do i need to slide the rubber/plastic cover back towards the cabin or pull towards me?
And does it matter which groove the little clip goes back into?
thehitmanuk
- New User
just wanted to say a massive thanks to you guys on the forum for your information on the c5 throttle cable fix followed your directions on how to access did the job and now she once again eats up audis and bmws well chuffed
thanks again
karl
thanks again
karl
