I have a Citroen C5 2.0 HDI LX 02 plate automatic. I am having a new comms unit installed. The current unit has indicators, wipers and radio control stalk but I was wondering can I get a comms unit that also has cruise control stalk and if so can this be fitted which would then give me cruise control or is there more to it than that?
Regards
Cruise Control Question
jgra1
- (Donor 2021)
- x 36
Re: Cruise Control Question
there is less
I have a CC stalk somewhere for a few quid.. add that to your comms and you are almost there..
you need a switch for the brake pedal, being an auto I am not sure... get from a scrapper (get the stalk too?).. and you may need a friendly forum member to 'lexia' the car to let it know it has cruise..
where are you based?
John
John
oneday
all comms units have the ability to be fitted with a cruise switch you will probably need a second brake switch it works the opposite to a normal switch ie open when brake is pressed. then you need someone with a lexia to switch on the rvv file. the bottom colum cowl is marked on the inside to show where to cot to accomadate the cruise stalk. all very simple and well worth doing new cruise stalks are not to expensive. make sure you get the one with the on off switch only and not the one that includes the speed limiter.
306 1.4 LX MERIDIAN
306 1.4 LX MERIDIAN
- x 1056
See here > http://www.frenchcarforum.co.uk/forum/v ... ol#p374746" onclick="window.open(this.href);return false;
