What engine you need the pump for ??....I know of a good one in my ex C5 2lt 8valve and one local in a 1.6 tdi out of a Pug....
Broke down, now will not start.
- x 1988
Re: Broke down, now will not start.
Very......ohhh la fecking lala if it is that
citroenxm
- Fallen Hero
- x 70
2.0 pump no good completely different.. needs to be from the 1.6 16v engine.. with the turbo on the front..
Citroen c4 2006 56 plate...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1988
the one in Wanstrow Somerset, is from a 56 plate Pug......I think its the same engine/pumps etc....
citroenxm
- Fallen Hero
- x 70
Needs to be same as yours so you can compare it with your engine.. the pug is the same things anyway.
Needs to be good and cheap as possible..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
oscar
- x 8
Ford/fiats could be same as they use that engine mind you ford use alot of Delphi
- x 1988
Give them a call and see mate
http://www.byrnemotors.co.uk/" onclick="window.open(this.href);return false;
- x 1988
SitRep
The car has now done 1500 miles....not a single miss fire
Starting is fine
Only bleeps at start up.( seats still need to be wired in)
Seems the EGR sensor elec- plug is a weak spot and always worth popping off, clean and replace.
Seems that Seat and AirBag wires need careful checking INSIDE the plastic "protector strip box" ! it had rubbed on the sharp edges of the plastic ....well done Citroen
So ...all well now....THANKS Guys...
Starting is fine
