Will this need to be machined?
Post Reply
evilally
My Cars:
Post by evilally »
In the middle of taking an XUD to bits and found this:
...the other 3 are perfect and look like new. This was the cylinder where I had a glow plug snap off in the head. I wonder if some debris has fallen down into the cylinder :( The engine did have a small amount of blow by, I had put that down to the crappy fibre head gasket it had fitted, but perhaps this was the reason. The middle ring on the piston was slightly stuck as well.
The piston crown shows signs of damage:
'96 405 1.6 GLX with 306 GTI engine on Cat cams @ 195bhp
'05 RenaultSport Clio 182 Cup, 102k
'97 406 1.9TD, 314k.
Chlorate
My Cars:
Re: Will this need to be machined?
Post by Chlorate »
Owwwwwuh...
That's pretty terrible.
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police :evil:
evilally
My Cars:
Post by evilally »
Bugger. I'll take that as a "yes" then? If I get it machined, will I need all 4 machined, or just the damaged one? Then new piston rings I assume? Where's my cheque book......
addo
Sara Watson's Stalker
Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
My Cars: Peugeot 605
Citroën Berlingo
Alfa 147
x 93
Post by addo »
Can you sleeve a diesel? That's what I'd be doing if someone will play along - restore the original bore diameter and fit a good used piston. Yes, new rings.
spider
My Cars: Soon, I hope...
x 77
Contact:
Post by spider »
I'm not sure you can sleeve them, then again it could be machined out a bit and oversize pistons fitted I guess. Not my area.
Andy.
evilally
My Cars:
Post by evilally »
I think what I'm going to do is source a decent bottom end. Would a DHX be a suitable donor for a DHY? I can't think why not?
spider
x 77
Contact:
Post by spider »
I think so and you avoid the (slight) risk of the DHY 'concern'* I think the DHX is the earlier unit ie pre 97. I'd have to double check that.
*Andy's personal conclusion on that 'concern' was N/A rods fitted to turbo engines.
Andy.
evilally
My Cars:
Post by evilally »
Cheers Andy, look what I found:
http://www.ebay.co.uk/itm/FIAT-DUCATO-B ... 2a2e42a25c" onclick="window.open(this.href);return false;
...bit of a bargain I think. The Ducato uses the XUD DHY engine as far as my research indicates. I have read of the DHY "problem" but my understanding is it's only engines made in certain years? It's of no consequence anyway, the engine is getting uprated rods as part of the top secret project ;)
My Cars:
x 92
Post by citronut »
looks like the reconditioning was just a jet wash off and a coat of black paint,
if it had bin re/conned properly they would have machined/skimmed the top of the block.
you can still see the imprint of the old gasket
Regards, malcolm.
Post Reply
