I have not checked, but have a hunch it might be that. I am collecting some today and I'll check once home (I ride to work)Fake Concern wrote:Sorry to hear of this. I take it you checked the fluid level?
Quite a few threads on C4Owners about this, such as http://c4owners.org/plugins/forum/forum ... 08679.post" onclick="window.open(this.href);return false;
so might be worth having a search.
Good luck with it
C4 VTS 180 Blog
Captain Slow
- x 3
Re: C4 VTS 180 Blog
Captain Slow
- x 3
Re: C4 VTS 180 Blog
Do you know which fuse it it? I'm going to guess mine has the same issue.daviemck2006 wrote:Mine don't work either, and with mot looming in a few weeks I had a wee look yesterday. The fuse is blown. I dont have an appropriate fuse but will get and and then see if that is all I need. The problem might be finding out what caused the fuse to blow. I hope it is as simple of replacing the fuse, pass mot and remove fuse!
daviemck2006
- x 496
Re: C4 VTS 180 Blog
It's f4 in the engine fusebox. Yellow 20 mini blade fuse
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
Captain Slow
- x 3
Re: C4 VTS 180 Blog
Superb. Thanks.
I went to the local Citroen garage at lunch, and after arguing with them for 10 mins finally got some Fluide LDS rather than the standard Power Steering Fluid they were trying to sell me. Apparently the electric pump in the C4 needs this stuff rather than normal. Hopefully a top up will cure the issue.
Captain Slow
- x 3
Re: C4 VTS 180 Blog
Sad times, the issue isn't fixed. The car also failed the MOT.
The failure was for low front pads and discs, a hole in the centre section and rear box, power steering failure and poor rear brake efficiency.
Bugger.
New discs and pads ordered from eBay (grooved)
New centre section and back box ordered from the link several pages back (thanks for the link)
Saturday will be spent replacing discs, pads and exhaust. Its then onto the power steering issue.
Exhaust cost £247, discs and pads £100.
I'm a bit annoyed as I was thinking about selling, but as its just cost circa £400 I think I might have to get some use.
Bugger.
- x 8348
Re: C4 VTS 180 Blog
Sorry to hear that..
Be interested to know what the cause of the failed power steering was..
Captain Slow
- x 3
Re: C4 VTS 180 Blog
My initial thought is something along the lines of a relay. It only fails when the car is warm.
In other news I purchased some Kawasaki green brake caliper paint
Fake Concern
- x 65
Re: C4 VTS 180 Blog
Sorry to hear of the other problems. Have you checked the battery and alternator as these can cause problems with electric power steering?
Captain Slow
- x 3
Re: C4 VTS 180 Blog
No, please elaborateFake Concern wrote:Now you're talking!Captain Slow wrote:
Fake Concern
- x 65
Re: C4 VTS 180 Blog
Don't know about the C4 specifically, but my mum's Polo suffered from a failed alternator & the first symptom was heavy steering as the electric power steering pump stopped working.
Captain Slow
- x 3
Re: C4 VTS 180 Blog
I have finally got round to dropping the C4 off at my mates garage to get the bits and bobs fixed along with a new MOT. He popped it on the rollers last night and it only pushes out 163 rather than the 180 it's supposed to do. Is there a common reason it could be down on power, such as Maf?
Citroening
- x 19
Re: C4 VTS 180 Blog
I just had a look over on C4Owners as I remembered reading something about the BHP of the VTS 180...
http://c4owners.org/plugins/forum/forum ... ost_137595" onclick="window.open(this.href);return false;
So apparently they're 174BHP, 177PS and they round it up to 180...
Sounds like you're 11 off then, as opposed to the 17 before...
Franklin
Captain Slow
- x 3
Re: C4 VTS 180 Blog
I see. A service and fitting the new exhaust may gain a few ponies then
Citroening
- x 19
Re: C4 VTS 180 Blog
Might be worth PMing Wozza over on C4owners as I seem to remember he's also got a GSR Induction Kit available which does free quite a few ponies...
Franklin
Captain Slow
- x 3
Re: C4 VTS 180 Blog
Car has an MOT again. Its had new discs and pads, new exhaust fitted and a new power steering pump.
Now do I keep it or sell it for something with green running through it...
