Rustproofing
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Check for compatibility, but if you get a good layer of the Hydrate 80 down, it should be suitable to overseal with a brushable stone chip coating. Ideally, three coats with adequate drying between...
Old-Guy
x 22
Re: Rustproofing
Unread post by Old-Guy »
addo wrote:Check for compatibility, but if you get a good layer of the Hydrate 80 down, it should be suitable to overseal with a brushable stone chip coating. Ideally, three coats with adequate drying between...
In my recent experience, "adequate drying between" in the UK is 24 hrs in a warm ventilated place for the first coat, then 36-48 hours between coats. Of course, if we get what passes for a heatwave in the UK (nudging 25°C) next week.... Not a good idea to leave it outside - you'd be amazed how much cr4p the slightest puff of wind swirls around close to the ground.
addo
x 95
Anything solvent based should be OK.
KP
x 27
Re: Rustproofing
Unread post by KP »
Maybe a layer or two of this stuff???
" onclick="window.open(this.href);return false;
