The suspension pipe that runs from front to the K splitter between the centre sphere and the off side rear wheel on the subframe, where exactly does this pipe run to at the front? Is it to the bracket on the bulkhead where four pipes come in together, if so which one? or does it go to a control valve somewhere? any help would be much appreciated.
Xantia 1.9TD saloon 1995
suspension pipe
- x 1477
johnlyn
- x 1477
John,
I think I was talking piffle - there could possibly be a connection after the height correcotr running to the front as this will be the feed for the rear brakes. I imagine that all the pipes from the rear will run to that connecting block, as that would be the easiest way to put them in. I guess you'll just have to wiggle and trace the pipe to work out which one it is.
johnlyn
I guess you are just about right on that one richard, have worked out that pipes coming from the brake doseur valve go to 4 block connector behind reservoir, 2 pipes on right go to valves of some description! 2 pipes on left towards underbody but again which one is it? somebody out there must know! HELP
