I have a 2002 2l HDi Rapier 307 sitting here, it wont start
If I bump start it, 2nd gear, pop the clutch turning the key, it bursts into life. There is no smoke form the engine, the engine and turbo pull well, no missing of juddering, firing on all pots well, infact it runs perfectly and pulls fine.
But once you turn it off it will not start again. It has lots of power and turns over fine, but just wont fire unless it has a bump irreverent if its hot or cold, or even it it was running 20 seconds earlier, and then runs perfectly with no warning lights on the dash!
Anyone any ideas, opinions appreciated fellas
