Hi guys,
The blow heater isn't working in my girlfriends Saxo 1.5sxd, What is the problem likely to be, anyhting I should be checking before taking it into a garage?
Heater not working in Saxo 1.5sxd
Jon
compbuild
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Jon</i>
This is quite common on the Saxo range. Provided the fuse etc is OK you can test the heater motor by disconnecting it and putting a live feed to it. If it works then the fault is usually with the Ignition switch, which has become overloaded and will need replacing.
Do you mean the ignition switch to start the car?
- x 1056
no need to replace the ignition switch. check this thread - http://www.andyspares.com/discussionfor ... ion,switch
compbuild
- x 1056
