removing plastic surround for stalks on steering collumn
boristhespie
x 4
Unread post by boristhespie »
C5 finally decided to give fitting the cruise control a go. Are there screws that will let me loosen off the plastic around the unit to fit the stalk before i cut a hole in it? I wanna make sure it works first.
C'est pas possible!
x 1055
Re: removing plastic surround for stalks on steering collumn
Unread post by wheeler »
There are 2x T20 screws that hold the column cowlings on then it just pulls down. Adjust the steering column reach fully towards you first to make it a lot easier. Remember don't cut the cowling till you have made sure it works.
I will be putting Cruise control on a C5 in the next 2 weeks so will take some pics & do a how to guide as it seems to be quite a popular topic just now.
boristhespie
x 4
That would be good. Thanks for that.
C'est pas possible!
