406 Hdi Starter on a 2.1 td & Clock Mileage Issue?
ceet12
Unread post by ceet12 »
Hello, my car is a 1997(8) 2.1 td 406 estate
sorry to bother with these questions, ive actually posted this on another forum aswell, so please accept my apologies if this is against any rulings, im trying to get as much info as possible
The starters starting to play up on my 2.1 td, ive confirmed this with a multimeter, so im needing a new starter
ive heard the hdi (valeo) starter is a better starter, more ampage and more powerful kickover on cranking, and also its a bonus for higher mileage vehicle with less valve clearance, (be handy if needed as more miles are clocked up!)
this is the post im relating to regarding the starter motor post 11
http://www.frenchcarforum.co.uk/forum/v ... =4&t=38095" onclick="window.open(this.href);return false;
basically ive read people fitting it to the 1.9 td i think??, can anyone confirm if this will fit on my 2.1td?? also there a lot cheaper new i think then an original one for the td, which will be harder to come by now??
The second question i have is all of a sudden my mileage clock has totally dimmed, its barely visible in the day and non visible at night (please have a look at included picture)
im not sure if these are a lcd unit?? does anyone know? or is it as simple as replacing a bulb behind the lcd display, i think its an lcd display>? could have sworn i had a simlar issue years ago and peugeot confirmed it was lcd??
if it is an lcd display can it be fixed without having to change to a new lcd display??, as obviously itl be costly to put the milage back exact on the new lcd display, thats if it is lcd??
or again is it as simple as a bulb replacement?
id appreciate any help as always,
Thanks again
Kindest Regards
EDIT*** Im finding it difficult to find a valeo starter on ebay for this? im i off the mark here? do valeo make starters for the hdi? if anyone has any links id be grateful, providing its ok with the rules
Cant upload image due to message "Sorry, the board attachment quota has been reached." ive tried to add it below
x 1238
Re: 406 Hdi Starter on a 2.1 td & Clock Mileage Issue?
Unread post by Peter.N. »
I think the mounting is similar on all the starters what you need to do is check that they have the same number of teeth. I have never tried fitting and Hdi starter to a 2.1 but they do seem the whap the engine over in the Hdi at a rate on Knots.
I believe the display is illuminated by one or more bulbs in the rear, I expect these need replacing.
spider
x 77
Unread post by spider »
There's one bulb for the odometer display. Its actually slightly different to the rest of the illumination bulbs, in that its classed as a "long life" bulb although a normal one will fit I'm sure. The panel comes out quite easily once you've carefully prised the trim off with a suitable blunt tool.
Regarding starters see this (may also apply to XU diesel units) > http://www.frenchcarforum.co.uk/forum/v ... 11&t=43319" onclick="window.open(this.href);return false;
Andy.
