Leaky HP Pump
Rhothgar
(Donor 2026)
x 222
Re:
Unread post by Rhothgar »
addo wrote:Glad to see the HP source is at stake.
You mean rather than the pump as a whole Addo?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
It was a bad pun.
I'm a pump-off, fix it 100% advocate (but didn't want to burden you with this attitude). If you do, make sure to examine how it's aligned, first.
Rhothgar
(Donor 2026)
x 222
Re: Leaky HP Pump
Addo. I'm all for a proper job.
You mean pulley alignment when putting it back on, I assume.
addo
x 95
Yes, the Service.Citroën exploded diagram is wrong in how it lays out the collets and cone nuts.
Rhothgar
(Donor 2026)
x 222
Re: Leaky HP Pump
Has anyone got a 4026 88 O-ring going spare they want to sell?
Citroen want to sell a minimum of 5 pieces!!!
Trying to work out what size it is. It states 19-TO 2.4mm
I assume this means 19mm. To Outside with a 2.4mm. section.
Would a 14mm internal 2.5mm. section O-ring suffice?
Thoughts/verbal abuse please!
Or if anyone needs one, let me know and I can post for cost+postage. Payment by PayPal.
x 8279
Re: Leaky HP Pump
Roger, I'd not try any old ring in this position as it's critical. Some O rings are not LHM resistant.
Five won't cost the earth and you can always sell what you don't need on here. Someone will have them.
Rhothgar
(Donor 2026)
x 222
Re: Leaky HP Pump
5 won't cost much? £6.75 I'll have you know. Hate wasting money!
x 8279
Re: Leaky HP Pump
Rhothgar wrote:5 won't cost much? £6.75 I'll have you know. Hate wasting money!
You're not. Flog 'em on at a profit. Quid a ring with a quid P and P. There you are. Can't say fairer than that...
Look at it this way Roger; five rings are less than a packet of fags and less that a couple of pints of beer. And they're better for your health!
Dommo
x 20
Re: Leaky HP Pump
Unread post by Dommo »
Looks to me like the accumulator is past it, sounds it too based on the click rate. I'd say the pressure is spiking when the regulator lets fluid through (because of a flat accumulator) which - along with old o-rings - could well be the cause of the leak.
Rhothgar
(Donor 2026)
x 222
Re: Leaky HP Pump
Are you suggesting that a replacement accumulator could be the cure and stop the leak?
x 8279
Re: Leaky HP Pump
Rhothgar wrote:Are you suggesting that a replacement accumulator could be the cure and stop the leak?
It's certainly not helping Roger. Dom makes a good pint there but I'd still replace the O ring as they do go regularly..
Rhothgar
(Donor 2026)
x 222
Re: Leaky HP Pump
I'll go round Dom's tomorrow for a pint of home brew then!!!
Dommo
x 20
Re: Leaky HP Pump
Rhothgar wrote:I'll go round Dom's tomorrow for a pint of home brew then!!!
Took me a while to get that one... I got there eventually!
Rhothgar
(Donor 2026)
x 222
Re: Leaky HP Pump
What a complete bar steward!
At my mates at the moment doing the o-ring and the car appears to have p*ssed out all its green blood.
I've depressurised the system so I assumed, rightly or wrongly, that the LHM loss would have been minimal.
I have a sneaking suspicion that there is, in fact, NO ball bearing in the pump and until all the LHM drains out, I ain't gonna know.
This is perhaps the reason why the car is clicking so regularly.
Surely with such low pressure in the system I only need to press on the spring and the flow should STOP, which, it isn't doing.
Any thoughts on these comments, guys!
Rhothgar
(Donor 2026)
x 222
Re: Leaky HP Pump
Anyone know the diameter of the ball bearing!!!
And is it a standard steel one or anything special?
