So I've done the easy bit and got myself a new heater matrix. Have to go and fit it now. Any tips? Do I just start stripping everything from the centre of the dash till I find it or what?
Cheers in advance.
Sent from my GT-N7100 using Tapatalk 2
Fitting a xantia heater matrix
- x 8305
Re: Fitting a xantia heater matrix
Ste, a good search on here will pay dividends but in short....
Take care removing the scuttle panel to avoid breaking it and the windscreen. Use a long-bladed sharp craft knife to slice the bonding sealant...
No need to remove the LHM reservoir.
Try to separate the heater matrix water elbow but if you can't don't risk busting it but revert to plan B and separate the second joint inside the car.
Disassemble the dash and note how all wiring runs - take a few pictures if need be - some runs are not intuitive. make a note of any odd screws and where they came from.
The seats do not need to be removed to get the centre console out. Motor them right back and recline as far as possible. Disconnect handbrake cables at calipers so the lever can be pulled up to the maximum extent.
On the bulkhead, undo the nut and washer that secures the RH side of the heater box.
Split the heater box by undoing the two gold 10 mm screws and nuts top and bottom. If the elbow didn't come apart, disconnect the matrix at the internal joint.
Manoeuvre the wiring loom well out of the way. Pull the heater box back and remove the old matrix. Clean out the heater box of spilt antifreeze and other crud that may have gathered.
Reassembly is a reversal of disassembly.
That'll get you started. have fun!
- x 94
isnt that what the glove box is for ( left over nuts, bolts, screws, and any other oddments you have left over )CitroJim wrote: make a note of any odd screws and where they came from.
i have never reclined the seats for this job, or disconnected the hand brake cables,CitroJim wrote: The seats do not need to be removed to get the centre console out. Motor them right back and recline as far as possible. Disconnect handbrake cables at calipers so the lever can be pulled up to the maximum extent.
Regards, malcolm.
OnlineRichardW
- x 1480
Like to a previous (CitroJim!) thread in here: http://www.frenchcarforum.co.uk/forum/v ... 11&t=29981" onclick="window.open(this.href);return false;
- x 8305
Maybe it's only necessary in a car with leathers and a driver's armrest Malcolm... If you don't disconnect the handbrake cables you can't, in my experience, pull the handbrake lever up far enough to allow the console to come out easily...citronut wrote: i have never reclined the seats for this job, or disconnected the hand brake cables,
Richard, thanks for posting the link!
h2ocooler
Good luck doing that, done it once and it was FUN, think it was about 4-5 hours it took me.
Have plenty of plastic tubs for the bolts/screws and mark on them where they come from, makes life so much easier when putting it all back.
Only reason i did it was the heater matrix was blocked, changed it then the next year it blocked AGAIN!!!!!!
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
- x 8305
Not unless there's a locality up your way called Dublin, Ireland Mikesuperloopy wrote:Stekelly, whereabours in uk are you, not northeast by any chance?
- x 694
CitroJim wrote:Not unless there's a locality up your way called Dublin, Ireland Mikesuperloopy wrote:Stekelly, whereabours in uk are you, not northeast by any chance?
Jaf
- x 42
With my car being a left hand drive is the steering gear likely to get in the way? I'll just bet it will!
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
- x 8305
No, because everything is a mirror image on a LHD car Jaf so you’ll be OK... The steering gear gets well in the way on an RHD car and the whole column has to be dropped down...Jaf wrote:With my car being a left hand drive is the steering gear likely to get in the way? I'll just bet it will!
Mike, that sounds like a good gig
I'm sure someone up your way will be doing a matrix eventually... Citroenmad's fairly local isn't he? He's got two Xantias
Jaf
- x 42
Hmm, thanks Jim. One less excuse then! Will do it one day.
addo
- Sara Watson's Stalker
- x 95
Xantidote
- x 5
Very useful having a second pair of hands to remove/lift out the dash from car, and for physically putting it back into car again
Martin
1995 Xantia TDLX (deceased
- x 8305
I'd say bloody essentialXantidote wrote:Very useful having a second pair of hands to remove/lift out the dash from car, and for physically putting it back into car again
