Xantia window regulator
CitroenCrazy
x 65
Unread post by CitroenCrazy »
Hi all
I know this is quite a common one, and has been mentioned a few times on this forum, but I wonder has any kind soul done an idiots guide to repairing a Xantia window regulator ?
I've removed the failed assembly from driver's door of my S2 estate, and true to form, the grey slider has broken. I have a replacement on the way to me from ebay, but I'm struggling a bit to see how to reassemble the wires. Apart from anything else, I seem to have three free ends ??
Fortunately, nothing looks too mangled, so I hope I can get it fixed fairly easily, but if I jump in and splash about, I'm likely to do more damage than I started with.
Many thanks
Andrew
x 3300
Re: Xantia window regulator
You will actually have 4 ends, as there are two cables. I have explained elsewhere on the forum how to re-assemble the mechanism; it isn't that hard but it is a bit of a PITA! I will assume you have the mechanism out and ready to work on. If I had pictures available I would post them. I have managed to do this myself, but it is awkward. The parts are a tight fit, and the tensioning arm and spring take practise to get them to line up properly (so when you have the motor, spool and cables off the frame, take the time to examine the arm/spring/frame layout).
Before starting, check both cables and the spool. If there are signs of damage I would seriously consider getting replacements for them first (a kinked cable is likely to pop off the spool, while a damaged spool could drop a cable).
Take the motor off the frame. The spool will come away from the motor. Fit one of the cables onto the spool, and wind it on until it gets to half way. Do the same with the other cable. They need to almost meet (groove next to each other, looking something like this when seen side on; _0_). Now secure them in place with tape (enough to hold them, but not too much, as you will have to remove it later).
At this point you can experiment without much chance of causing damage. Fit the slider onto the frame (making sure to get it the right way round). Now fit the tensioning parts (spring and arm) onto the lower end of the frame (again, make sure to get it right). This has to line up properly, otherwise you cannot get the cables to fit. Once you are satisfied the parts are fitted correctly, you can get onto the next bit.
Now re-fit the motor and spool, making sure to guide the cables through without snagging/kinking. Holding the frame in its' working alignment, IIRC you need to take the anti-clockwise cable (the one pointing up) over the top wheel, and then down onto the slider (and then fit it to the slider). Then take the other cable and fit it onto the other point on the slider. Now comes the tricky bit.
This requires some strength, and percywotsits (alright, perseverance). What you need to do is to get the cable onto the tensioner, and it is fiddly. The arm has two grooves; one at the pivoting point, the other at the end. Fit the cable over the pivot groove, and then over the end groove. If you have strong thumbs it will help. It can be done (I HAVE done it myself), but you might find that the air turns blue. A short, blunt flat screwdriver can help, but be careful.
Once you have got it all together, remove that securing tape on the spool, re-fit the frame, and good luck.
CitroenCrazy
x 65
Hi James
Thanks very much, it's starting to make sense now. I'll take some pictures as a I go along, & hopefully will be able to fit them to your words.
Cheers
Andrew
x 3300
If the cables or spool are damaged, then this might be worth a look;
http://www.ebay.co.uk/itm/CITROEN-XANTI ... 4ab932303d" onclick="window.open(this.href);return false;
MJM
Unread post by MJM »
These may help.
http://www.flickr.com/photos/77195466@N05/" onclick="window.open(this.href);return false;
MJM
1999 Dante red Xantia Exclusive 2,0 petrol. No smelly diesel for me. Now re-homed
2007 Wicked Red C5 Exclusive. Now a smelly diesel automatic for me.
x 8313
MJM wrote:These may help.
I'll say, most valuable :-D
MJM
I've a few more of the regulator (not Will the dog!) if anyone needs them.
MJM
