Checked everthing I can and still have boost fault
taffy
My Cars:
Re: Checked everthing I can and still have boost fault
Post by taffy »
If The egr don't throw up a fault on The c5 it might work
06 silver 1.6 hdi vtr c5
08 black C4 GP 2.0hdi vtr
taffy
My Cars:
Post by taffy »
Dawsy if u about swindon on weekend I could meet u somewhere and we could try it if u like
dawsy 22
My Cars:
Post by dawsy 22 »
taffy wrote:Dawsy if u about swindon on weekend I could meet u somewhere and we could try it if u like
Cheers for that taff I am busy at home this weekend but maybe we could hook up in the future to sort these monsters out I am definitely going towards the stuck vanes in the turbo the reason for this in my way of thinking the turbo used to overboost until i fixed the vacuum leak on the swirl diaphragm (which was in that condition for a long time and a lot of miles)ever since i fixed the vacuum leak i have had this problem so I am thinking that once vacuum was applied the vanes were stuck in a mid position and have stayed there ever since,now to find a way to unstick those vanes
Thanks Ian
waynedance
My Cars:
x 8
Post by waynedance »
You may be able to get some long nose pliers on the shaft of the actuator and move back and forth while applying WD40. I did strip down an old turbo to see how it all worked.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
dawsy 22
My Cars:
Post by dawsy 22 »
waynedance wrote:You may be able to get some long nose pliers on the shaft of the actuator and move back and forth while applying WD40. I did strip down an old turbo to see how it all worked.
Isit best to get at it from below,it seems quite inaccessable to me,when i looked at it the other day the shaft seemed clean but I guess i cant see whats going on inside the turbo i just hope it is this and i can get back to full power as i have been a long time without itThanks for all the comments guys as i have said before without this forum the car would have been baled a long time ago
Thanks Ian
taffy
My Cars:
Post by taffy »
Yea no probs mate u let me know when ur about and we will have a go...
taffy
My Cars:
Post by taffy »
I got car ramps too :)
waynedance
My Cars:
x 8
I changed my turbo in January was not to bad a job but needs to be on a ramp.
I took some pics of the turbo insides, I changed the turbo as the actuator rod was sort of detached from the valve at the end where the vac pipe goes.
https://docs.google.com/file/d/0BwygWxo ... sp=sharing" onclick="window.open(this.href);return false;
Post Reply
