Did you get a printed note telling you that instructions can be found on disc 1 - and if you can't get the Keygen to contact the seller? I suspect that everyone has to contact the seller and at the same time send the installation code. Before you do, try this as your keygen DHLK4WPO2CTGPNL3............. It may work..allanmc wrote:Hi, I bought the £4 citroen manual discs on e bay last week, to cut a very long story short, I tried to download them but couldnt download No. 2 disk which tells you how to do the work I have tried to start again but am unsuccessful can someone help please
allanmc
ebay purchase
JohnD
- x 72
Re: ebay purchase
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
spider
- x 77
Re: ebay purchase
You'll want three discs and the install instructions.
The generator is a jar file usually.
Andy.
allanmc
Re: ebay purchase
Sorry I didnt get back sooner, I should have told the full story it was my son who tried to download these discs and found that the No. 2 disc was empty and also when loading No.1 it never asked for No.2 which I think might hold the instructions for doing work on the car after loading disc 3 we had diagrams of various parts of the car which was good but still no instructions, contacted the seller and he sent another set of discs but the were just the same, so my son decided to uninstall all the data but so far has been unsuccessful we have tried everything we can think of even tried to restore the computer to an earlier date but computer would not accept it can you help please
allan
allan
Xantia 2.0i SX Auto, 1999
- x 1471
Re: ebay purchase
I have bought a set of the same DVDs, and am having a similar problem.
The keygen works fine, and installation of DVD1 proceeds (rather slowly). After about 8 hours it asks for DVD 2, but the DVD drive is locked, and DVD 1 cannot be ejected.
If DVD 1 is manually ejected using a pin, and DVD 2 inserted, the drive spins up, but DVD 2 is never read, windows explorer still shows the contenets of DVD 1 and the installation program does not recognise that DVD 2 is installed. Pressing cancel causes it to abort the SEDRE installation and aks to DVD 3 which contains the Service Box software, which then installs normally (another 8 hours).
So any ideas on how to get windows XP to reset the DVD drive and actually read DVD 2, without aborting the install.
I have read online that DVD 2 contains the information for older cars, such as XMs and MK1 Xantias
Ben82
- x 7
Re: ebay purchase
Not installed from disc, but did you close the keygen before trying to swap discs? also have you tried going into my computer and right clicking on the Drive, and clicking eject?
I did a full install of SEDRE/DocBackup (using all 3 discs version 5.2012), and don't get any wiring info for the XMs or Mk1 Xantias.
2004 Citroen C5 3L V6 Auto
- x 695
Re: ebay purchase
Sounds like your drive is having difficulty reading the disk - there is no way the drive should be "locking" as Windows XP does not by default lock the DVD drive eject even when files are in use...that's a sign that the drive is having real difficulty with the disk.xantia_v6 wrote:I have bought a set of the same DVDs, and am having a similar problem.
I had a similar problem with my ebay copy - Disk 2 really struggled to read on the intended computer, you can tell by the drive constantly spinning up and down. I think it eventually failed to read the disk with an error then the drive could no longer read any other disks until I did a full power down of the PC. Disk 2 is mostly Sedre, if you do an install without Sedre it will skip disk 2.
Try just copying the contents of the disk to a folder on your PC to test the readability of the disk - I bet it will struggle to do that as well.
I found that while my desktop PC couldn't read the disk my laptop could (just) so I made a copy of disk 2 on the laptop and then used that to install on the other PC successfully.
Your problem is most likely just a combination of an old/tired/dirty DVD drive and a poorly written disk.
Service box is slow to install but not 8 hours per disk
- x 94
Re: ebay purchase
my son installed my version havent realy checked how much and doesnt work as yet,
although we tried looking up the workshop manual for the synegie/ulasyess, and it asked for the rp No.
didnt try further yet
Regards, malcolm.
spider
- x 77
Re: ebay purchase
Just put in a fake RP if needed just to play with it a bit, although it won't be 100% accurate.
Does it run very slowly and feel always like its on the brink of breaking ?
Andy.
- x 3296
Re: ebay purchase
I bought a set of these discs, and mine worked without any problems. The only real issue was how long it took. Disk 3 is a dual layer DVD, with about 8GB of files to install (which took 3 hours on my PC, which is no slouch).
- x 695
Re: ebay purchase
Yep.spider wrote:Just put in a fake RP if needed just to play with it a bit, although it won't be 100% accurate.
On my old Pentium 4 with 1GB of ram it really pushes the ram limit of the computer. It runs a full tomcat java application webserver in the background which consumes most of the available free ram, there also seems to be an intermittent memory leak issue, about 1 out of 5 times when I launch it it never finishes loading and just keeps consuming more and more memory until the computer runs out of both physical and virtual memory, at which point the whole computer grinds to an unusable halt where I can barely log out or shut down the computer. Even when its working its quite sluggish.
Not the most efficiently written software!!
- x 695
Re: ebay purchase
Thinking back I might have exaggerated a bit on how quickly mine installed, it probably was about 4 or 5 hours - but that's for the whole lot, not 8 hours per disk.Hell Razor5543 wrote:I bought a set of these discs, and mine worked without any problems. The only real issue was how long it took. Disk 3 is a dual layer DVD, with about 8GB of files to install (which took 3 hours on my PC, which is no slouch).
- x 1471
Re: ebay purchase
The vendor sent me a replacement disk 1, but it behaved the same way. I then tried installing on another XP machine (without a DVD drive) by sharing the DVD drive from the first machine, and it installed correctly. No idea what is going on....
So now off to find an earlier version...
I found that also. I pointed it out to the ebay vendor and he said he had not noticed and gave me a refund.Ben82 wrote: I did a full install of SEDRE/DocBackup (using all 3 discs version 5.2012), and don't get any wiring info for the XMs or Mk1 Xantias.
- x 695
Re: ebay purchase
I think you'll find that none of the versions of Sedre available include wiring diagrams for the XM or Xantia Mk1, mine doesn't have them either...
- x 1471
Re: ebay purchase
Which version is yours?Mandrake wrote:I think you'll find that none of the versions of Sedre available include wiring diagrams for the XM or Xantia Mk1, mine doesn't have them either...
- x 3296
Re: ebay purchase
I have 4.0.2, and it doesn't have diagrams for the XM or the S1 Xantia.
