HDI 90 Front section exhaust HELP NEEDED!
Duke137
Unread post by Duke137 »
Please advise (as post further down) If I buy an XUD 1.9TD Front "swan neck" exhaust section from ebay (as it is cheapest) will it fit the HDi 90 engine ok?
Link to advert :
http://www.ebay.co.uk/itm/OFFER-CITROEN ... 753wt_1132" onclick="window.open(this.href);return false;
Northern_Mike
Re: 110 or 90?
That's a 90... no pipes to the intercooler etc..
Duke137
Re: 110 or 90?
Thank you
citroenxm
Fallen Hero
x 70
Re: 110 or 90?
Unread post by citroenxm »
Ha.. notice the front cover has the corner on the right cut out ready for 110 engines with the extra intercooler pipe..
A very sad...
1994 XM 2.1 d auto
Duke137
Re: 110 or 90?
Can anyone tell me, would the front exhaust and cat section be the same between 110 and 90's?
citroenxm
Fallen Hero
x 70
Re: 110 or 90?
Nope.
90 bhp is the same size as the Older XUD TD exhaust.. The 110 is larger so they are not compatible..
A very sad...
1994 XM 2.1 d auto
Duke137
Re: 110 or 90?
So if I buy a 1.9 XUD TD Front section and cat on ebay it will fit this car pictured above?
Duke137
Re: HDI 90 Front section exhaust HELP NEEDED!
bump original post changed
citroenxm
Fallen Hero
x 70
It should do.. DISCLAIMER:I do NOT want to be held responsible for the discovery that the TD pipe wont fit a HDi. (To cover my back) However - I did fit a NON Cat TD pipe to an X Plate HDi 90 a few years ago..
A very sad...
1994 XM 2.1 d auto
Duke137
Thanks very much, turns out I need the whole system as the rear end broke today! Luckily the mid section is resting on the rear roll bar so I have been driving it as usual ghetto style :)
x 3296
Is the cat section ok? I believe you can get a repair pipe to fit, and this MIGHT be one;
http://www.ebay.co.uk/itm/CITROEN-XANTI ... 35bfbf5713" onclick="window.open(this.href);return false;
Duke137
Hell Razor5543 wrote:Is the cat section ok? I believe you can get a repair pipe to fit, and this MIGHT be one;
Hi mate
Thanks for the info, tbh I think I will just replace the whole lot with a new system as I reckon you get the whole lot from the mani back bought and fitted for £200? It's done then, I already spent £400 on it in Feb at MOT time and to be fair, even though it's a bit tatty it's everything I need from a car and more with a busy life and a family etc, I love it :)
x 3296
If you are capable of swapping the bits yourself, take a look at carparts4less. You can get a cat and backbox for about £100, although you will need the clamps, gasket, mounts etc.
x 94
Unread post by citronut »
look on Bosals web site as you can compare all the different models
http://www.catalogue.bosal.com/pages/ex ... search.php" onclick="window.open(this.href);return false;
Regards, malcolm.
Duke137
http://www.catalogue.bosal.com/pages/ex ... r=02495005" onclick="window.open(this.href);return false;
This be the one I think, I'd buy it if you could buy directly from the website! Had a couple of bosal systems on my BMW E30's over the years, great quality items IMO
