Spray to clean LHM filters + what is the small clip
charentejohn
Unread post by charentejohn »
Just cleaned the filters and rather than use a load of petrol I used one of those little plant sprayers full of petrol
Works a treat as not poerful enough to damage them but pushes stuff off the mesh.
One question though is what is the small S shaped clip I found in the bottom of the reservoir.
I read the LHM change guide and it mentioned a clip however, when I removed the pipe section from the reserevoir it caught on the edge and the ovel type filter came off.
I can't see anywhere the S shaped clip fits, but the guide implied it was for one of the filters.
You must be the change you want to see in the world - Mahatma Gandhi
Xantia HDI 90SX C3 2005 and C3 2006 both 1.4i sensodrives
x 94
Re: Spray to clean LHM filters + what is the small clip
Unread post by citronut »
it clips onto the small spigot at the bottom side edge of the long rectangular filter, then swings over and clips to the the adjacent housing
Regards, malcolm.
Sid_the_Squid
Unread post by Sid_the_Squid »
Found a picture on google for you, if your a visual person like me might help.
Image isnt rendering in the preview, so heres a direct link if it dosent work
http://xantia2001.web.fc2.com/m_img/LHM_filter2.jpg
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
charentejohn
Thanks guys, I did see the moulding on the oval filter but couldn't see how it worked.
I may have got it eventually but it would have taken a while / forever, especially as the tubes are still connected so not easy to see stuff like that.
My original guess was it pushed into a slot somewhere so that is what I was looking for so would not have thought of that.
All going back together tomorrow then it is new rear Sphere time :)
x 5677
superloopy wrote:Oops ... picture a bit on the large side, what's the recommended settings?
Ideally 700px wide Mike, or a thumbnail.
x 94
charentejohn wrote: especially as the tubes are still connected so not easy to see stuff like that.
sorry to hear that, was it after having a surgical procedure they were fitted restricting you vision/eye sight :shock: :twisted: :-D :wink:
Regards, malcolm.
