Rear LHM leak
- x 1479
Re: Rear LHM leak
Combination thread created in handy hints and tips http://www.frenchcarforum.co.uk/forum/v ... 11&t=44218
c.morewood
- x 55
Re: Rear LHM leak
Good thread Richard .. well done!!
As you say this can only become more common as the cars age. I'm sure this will give a lot of owners the detail to tackle this themselves.
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- x 8275
Re: Rear LHM leak
Excellent idea for a test rig Richard
I did think of using my sphere tester but about the best I'll get out of it is about 60 bars whereas with the hydraulic press the world is my oyster..
The two cylinders Neil has donated arrived today
That was excellent service from the post office and also had a copy of the Northumberland Gazette to enjoy reading... The cylinders came wrapped in it..
Neil, thanks ever so and I'll report progress in due course...
- x 94
Re: Rear LHM leak
wont you sphere tester pump the ram up to at least what it normally runs at ,
thats if you have a big enough winding handle
Regards, malcolm.
- x 8275
Re: Rear LHM leak
True Malcolm but pumping it up in the press may more accurately reflect what happens when the wheel hits a bump and there's a surge of pressure. I imagine that if it's going to leak that’s when it will happen...
I can do both...
I can do both...
- x 7163
Re: Rear LHM leak
Happy to help. Not sure which issue of the Northumberland Gazette I used. Maybe the one with the 106 year old from Bamburgh who attributed her long life to "a teaspoon of whisky in her morning tea every day".
For those unfamiliar with Northumberland this is Bamburgh-its out the right window as you travel from Newcastle to Edinburgh on the east coast main line, but its far better to have a leisurley drive right up to it and walk for miles on the deserted beaches and drink in the beauty and the solitude. Go a bit further South and drink in something else at the Ship Inn at Low Newton by the Sea-but dont park in the National Trust Car park-go to Embleton and work up a thirst with a walk along the beach-its an absolutely classic thing to do in Northumberland.
Add a lively labrador...it doesn't get much better!
- x 5645
Re: Rear LHM leak
I really should get myself up there for a look around. Furthest I have been was Alnwick, at midnight, looking for Aurora Borealissess but they weren't playing out that night
Only lived here 33 years, mustn't rush these things.
c.morewood
- x 55
Re: Rear LHM leak
The latest in the Saga... i must have done something wrong to someone somewhere... or is it just 2013? Unlucky for some?
I was trying to discover why she wouldn't rest at the nominal mid position. Only fully up or down.
I took Simon's (Mandrake) advice and checked out the front dog legs and lubricated them.. only to find on closer inspection that the dog leg complete with ball joint had separated from the height adjuster.. so I was left with a pin sticking out of the dog leg ball and a hole where the pin should 've gone.
http://s120.photobucket.com/user/cmorew ... 0.jpg.html" onclick="window.open(this.href);return false;
Since I didn't have a lot of time, I decided to put a small cable tie round the end of the dog leg and another around the adjuster and loop them together to try to keep the pin in position, till the replacement arrives.. It seemed to work and a few citaerobics later, I was satisfied that it would hold for the 40 mile journey later in the day.
Well I moved the car to clear everything up underneath only to find a pool of oil on the ground.. and yes you guessed it the other cylinder has let go in exactly the same way.
So i guess the warning is to members Be Prepared... if one goes .. the other is on its way out too.
I guess there might have been a bit more strain on it if the repaired cylinder isn't working as it should but obviously it was badly corroded as well.
One good thing came out of it .....Jim you'll have another cylinder to work on shortly.
I just hope this might be an end to my run of bad luck
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- x 1479
Re: Rear LHM leak
Bad luck Chris...
At least you know what you are facing getting it adrift....
- x 8275
Re: Rear LHM leak
I've had exactly the same thing happen to a front height corrector Chris. On an Activa and that truly was a test of fortitude as I needed to do the job and it was done in sub-zero temperatures laying on concrete
The Activa is hardest so yours should not be too bad at all. Weather and space will both be on your side a little I trust but I do feel for you - it has been a bit of a game
Once the corrector is out it's easily repairable with a spot of weld to the ball shank. It's only riveted in and it's the riveting that fails.
Neil, that picture is something else
It's really lovely and very atmospheric. I've not bee quite that far north either - in fact the furthest north I've ever been is about 20 miles beyond Steve's place...
- x 7163
Re: Rear LHM leak
Thanks Jim and Steve pleased you like the pic, but apologies to Chris as I dont want to turn the thread into an advert for the Northumberland Tourist Board
I guess I have got away with the gratuitous picture of Bamburgh Castle on the grounds that both Chris and Richard could possibly do with a bit of calmness and serenity.
I know speaking personally, when the frustrations of long fruitless hours spent working on the car begin to take their toll, a theraputic walk with a lively labrador can help
regards
regards
- x 94
Re: Rear LHM leak
it could be to do with were the moooooon is,
no really the other one would have let go sooner or later, but i think every time you put the car fully up on its highest setting this puts more strain/force on the cylinders, as it pimps them up to there maximum,
hope you dont suffer like the first time round
Regards, malcolm.
c.morewood
- x 55
Re: Rear LHM leak
I've got 2 other cylinders and a front height corrector arriving next week .. so hopefully ......
Its just a shame the other cylinder couldn't have lasted out that long.
Jim I'll try that spot weld and then I'll have a spare hopefully.
Do you want my 2 cylinders as spares/repair or should I get the 1 repaired and hold them for anyone with a similar problem?
Thanks for the beautiful picture.. and the previous advice.. no need to be sorry.
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
c.morewood
- x 55
Re: Rear LHM leak
Quick update on using a puller to remove the suspension pin..It didn't work for me.
I thought it was working as the pin appeared to be very slowly emerging from its lair.. but it seems that the ring was winding one from one end and unwinding from the other giving the appearance of it working and the pin coming out. So tomorrow morning I'm going to try a new nail punch or two and if that doesn't work, it'll be the arm off as you suggested Richard.
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- x 8275
Re: Rear LHM leak
I tried removing the pins on the subframe I have growing in my garden on Saturday Chris and did not even begin to succeed. I tried pulling via the loops in the clips and saw the same as you in that they just started to unwind...
Does the pin hole go right through the arm socket or is the hole into which the pin fits blind? Although there's plenty of rust around my scrap frame I could see no corresponding hole on the other side of where the pin enters the arm.
