Synergie blowing cold
x 94
Unread post by citronut »
my daughters Synergie (the lorry )
a week or so back she said the drivers side was blowing stone cold whilst the passengers side was still blowing hot,
now passengers side is blowing virtually cold all but the slightest hint of warm,
it dose have two blowers one each side,
Regards, malcolm.
miked
x 6
Re: Synergie blowing cold
Unread post by miked »
Sorry Malcolm, this is probably not going to help but I am known to ramble on about things I only think I know about.
I used to drive a synergie at work and I can't remember it having dual heat control. Maybe a different or older model. Are you sure it has two blowers?
At home we have a Pug 807 (C8) which was the new version of the synergie and it has three blowers, only one blower does both the front vents. (Getting to the main blower when it packed up was a challenge) The heat distribution to either side is done using motorised flaps.
x 94
thanks for your reply
i can ramble on sometimes also :o :-D :roll: :wink:
according to service citroen using the chassis No. it shows two blowers,
although i cant see how/were to switch dual zone on/off
Regards, malcolm.
x 94
nudge nudge bump bump
any ideas/help
Regards, malcolm.
Harlequin
x 24
Unread post by Harlequin »
air in the system?
x 94
shouldnt be as the last time the cooling system was drained was when i did cam belt tensioners and water pump, that was a few months back now, since when the heater was working well
Regards, malcolm.
x 1056
Unread post by wheeler »
Are the matrix pipes getting hot ? cant think i've ever seen a synergie with dual zone heating ?
Harlequin
x 24
on service citroen there is 1 with dual fans , don't think its dual zone though?
Harlequin
x 24
ofc the heat matrix pipes are behind the fuse box so easy enough to see if there warm :D
x 94
Harlequin wrote:ofc the heat matrix pipes are behind the fuse box so easy enough to see if there warm :D
i hope they are not getting that hot i can "see" how hot they are :shock: :roll: :wink:
it seems it is not dual zone, so why two fans, and why did the drivers side go stone cold whilst the other side was still up to full temperature,
and now the passengers side is all but cold with just the faintest of warmth coming out the vents
Regards, malcolm.
Harlequin
x 24
I was rather silly with the see them comment - ofc I meant touch
so that beggers the question - are they warm to the touch?
x 94
Harlequin wrote:I was rather silly with the see them comment - ofc I meant touch
:-D :-D :wink:
Regards, malcolm.
x 94
i had a look at the Lorry (Synergie ) today, both heater hose's get hot, and the end of the matrix is hot,
pluged the DIS-LEXIA ( 30pin plug ) up it but no dialogue what so ever even on a global scan,
so were/which is the diagnostic socket fuse???
and dose anyone know the layout/which/what flap motors do what and were they are situated
Regards, malcolm.
x 94
nudge nudge
or do i have to wait for the supper doooper pirate :roll: :wink: software i have bought from ebay
Regards, malcolm.
