c5 hdi tyre pressure
toothbrush
New User
Unread post by toothbrush »
hi, recently bought a c5 diesel 2 litre and not sure about the tyre pressure. it says on sitcker on door 2.3 front and 2.5 rear - but i checked online before seeing sticker - yes - icant beleive i didnt see it originally - all online site say 2.3 fron and 2.1 rear? puzzled? :? . also any idea how to increase hot air flow through foot area - can barely feel it.
x 5675
Re: c5 hdi tyre pressure
I'd go with the sticker (and do).
Re: footwell airflow. It would be worthwhile to check the condition of the pollen filter. If that is OK then the problem is likely to be warped flaps not opening up the flow to the footwell or broken splines on the motor that moves the flaps.
Welcome to the FCF :welc:
toothbrush
New User
many thanks for help. i thought the sticker surely must be right , but all the website were saying the same and 2.1 and 2.5 are pretty different - shall sort tomorrow as just been running car with all 4 tyres at 30 #-o .
toothbrush
New User
forgot to say its an old 2002 c5, but i must admit its my first citroen and i like it. especially the crazy suspension , ha ha , not experienced that before!
x 5675
If you get chance to attend one of the rallies (one coming up on the 7th April) you may be able to experience some 'proper' Citroen hydraulic suspension. C5s don't really compare with earlier models. An XM would be a good place to start.
Reason: Corrected misinformation.
